Old 02-13-2022, 12:20 PM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
What battery are you guys running? Any lighter weight options?
Hi, I am probably going to replace my battery this season as it is still on the original, I'll put the current battery into something else and put it to use instead of tossing it. I have been researching but most of the threads are old.
I have narrowed it down to these as my top choices,
Braillebattery - B3121 - Lightweight AGM Battery $241.49 USD 6118 mount $ 20.00
Braillebattery - i34RX - Intensity Lithium battery $1,049.99 USD
ODYSSEY Performance Battery - ODP-AGM94R H7 L4 (94R-850 (LN4-H7) $307.96
ACDelco 88864542 - ACDelco Gold Automotive AGM Batteries ADO-94RAGM $166.00
Optima Red or Yellow?
I like the Braille B3121 options but the size has me a bit nervous for a weekend vehicle, I do hook car to a tender if it is going to be sitting longer then a week.
I have used Ac Delco / Interstate/Optima red and Diehard in the past.
I have a Die Hard in my truck that is at least 8 years old probably closer to 10 and it is still going strong.
I may put a Ac Delco back in it but which model? AGM Gold? 48 vs 94 Size?
Thank
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 02-13-2022, 04:59 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
A thousand bucks for a battery? OMG! Obviously worth it in elite racing, but otherwise?
I will of course recommend what I did: replace the original AC Delco with the exact same thing. The part number is in the OM.
Old 02-13-2022, 05:28 PM   #3
RS/SS '10
Drives: 2010 2SS/RS
The same
RS/SS '10 is offline   Reply With Quote
Old 02-13-2022, 06:12 PM   #4
Joe.G
Joe.G's Avatar
I am not considering the $1000.00 Battery, I just posted their two options, I would rather stay around $200 Range. They did say they average about 15 years from the $1,000 option. I am leaning towards the AC Delco, According to GM's parts list there were 6 Different battery options, My car is covered at the moment so I am not sure which one I have.
SCT X4 Dynosteve,
Old 02-13-2022, 06:18 PM   #5
Royal Tiger
I went with a Diehard in the original size. Huge, but I don’t even use a tender and it turns right over every spring.
Old 02-13-2022, 10:21 PM   #6
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I'm thinking the Diehard as well. AGM in the H7 size is $209 at Autozone. Seems steep, but I always had good results.
FasNuf is offline   Reply With Quote
Old 02-13-2022, 11:21 PM   #7
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
I bought one. Drove it 2x in 3 yrs. Cells went bad. Wouldn’t hold charge. Got a duralast. This way I got a Warranty cause I ordered the AC Delco online.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 02-14-2022, 05:38 AM   #8
Joe.G
Joe.G's Avatar
DO you guys recommend AMG?
SCT X4 Dynosteve,
Old 02-14-2022, 06:52 AM   #9
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
In the field I've found that lead acid batteries outlast the AGM batteries...but that's just been my experience. And they're less expensive!
NOT A 45 is offline   Reply With Quote
Old 02-14-2022, 07:10 AM   #10
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
AcDelco 94R or Odyssey.
chevy pilot is online now   Reply With Quote
Old 02-14-2022, 10:28 AM   #11
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Been having luck with NAPA batteries. Not sure who makes them. I'm done with Interstate batteries, nothing but issues. Original Delco battery lasted about 10 years.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 02-14-2022, 11:47 AM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Same here too...
1JEWLDSSRS is offline   Reply With Quote
Old 02-14-2022, 06:16 PM   #13
91Zman
91Zman's Avatar
Drives: '13 1SS/RS IOM white stripes
Original....
91Zman is offline   Reply With Quote
Old 02-14-2022, 08:07 PM   #14
Joe.G
Joe.G's Avatar
Probably go with AC Delco again, Summit has decent prices on them.
SCT X4 Dynosteve,
