TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 03-08-2016, 08:20 PM   #1
djpelosi
djpelosi's Avatar
Drives: 2010 Camaro 2SS/RS
Interior door handle
Today my drivers side door handle broke. I took the door panel off and a piece of the actual door handle itself that the pull cable connects to broke, stopping the cable from being able to connect to the handle. Does anyone how to remove the interior door handle? I didn't see any bolts or screws so it may just be a pop out or something but I wasn't able to get it out or find any videos/tutorials online.
Any help is appreciated
Thanks
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers
3" Full exhaust w/ Off-Road H-Pipe
Bo White Ported Throttle Body
Hurst Short Throw Shifter
Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires
Build Thread
djpelosi is offline   Reply With Quote
Old 03-08-2016, 11:40 PM   #2
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
To remove the trim panel you will need to remove the perimeter fasteners. There are two across the bottom, one on the side by the hinge, one hidden below the door pull cup rubber insert and the other hidden behind the inner door pull handle (plastic trim piece that snaps in behind the handle). The rest are buckles and hangers that snap or slide off.
cajun1le is offline   Reply With Quote
Old 03-09-2016, 08:31 AM   #3
djpelosi
djpelosi's Avatar
I know how to pull off the door panel.. I was asking about how to remove the interior door handle itself.
2010 Camaro 2SS M6
Build Thread
Old 03-09-2016, 08:45 PM   #4
cajun1le
The Mechanic
cajun1le's Avatar
I read your post... The reason why you are unable to remove it is because it's part of the inner door trim panel.
http://www.gmoutletparts.com/auto-pa...trim-door-scat
See item #8 to the left in the illustrated parts diagram? Notice how that part number is not listed on the right side parts table listing but it is listed within box #1. That means the part cannot be sold by itself, but rather as a kit. The easiest thing I would suggest for you to do is to go to your dealer and give the parts rep your VIN to ensure you order the correct inner door trim panel.
Old 03-10-2016, 01:55 PM   #5
djpelosi
djpelosi's Avatar
http://www.carparts.com/details/Chev...wcB&redirect=1
Part number REPCV462120
Just because GM doesn't sell the door handle by itself doesn't mean nobody else does. The door handle assembly itself has to be able to come out if this part above is available to be sold without replacing an interior door panel.... otherwise what's the point? I see what looks like a tab on the top so it looks like it may be able to be popped or maybe I could pry it out, but I wanted to make sure this wouldn't break anything further in case someone else had also run into this.
2010 Camaro 2SS M6
Build Thread
Old 03-10-2016, 02:02 PM   #6
JMT
JMT's Avatar
Drives: 2013 1LT
I may have one if you can send a couple of pics of yours I can verify but pretty sure they are all the same from 2010-2015
JMT is offline   Reply With Quote
Old 03-10-2016, 02:14 PM   #7
djpelosi
djpelosi's Avatar
I can buy one I just need to know how to remove the door handle assembly itself so I can install a replacement.
2010 Camaro 2SS M6
Build Thread
Old 03-14-2016, 05:16 PM   #8
JMT
JMT's Avatar
Drives: 2013 1LT
Door handle assembly removed
$30 shipped. There are 3 plastic rivets that you carefully drill the tops off and it pops out the front. To reinstall you drill small holes in the remaining portion of the plastic rivet and use short self tapping screws with washers. Done!
Old 03-14-2016, 05:17 PM   #9
JMT
JMT's Avatar
Drives: 2013 1LT
Another pic
