Vararam
Old 12-23-2012, 06:27 PM   #1
Vinz68
Vinz68's Avatar
Drives: 68,69,72&10 Camaro's 12 CTS-V
Rear sways when on throttle
When i get on it it feels like i have 2 flat tires...... The tires and air pressure are fine. Anyone else ever have this happen? If so how did you fix it? I have Pfadt springs and swaybars in it for a while now and it always drove fine.
Any help would be great Thanks!!
Vinnie
Vinz68 is offline   Reply With Quote
Old 12-23-2012, 08:54 PM   #2
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Never heard of that before either. Is this all of a sudden? Not sure I follow what you are feeli g
My Build Thread
http://camaro5.com/forums/showthread...=1#post5036900
Maureen@Rodgers Chevrolet...The best prices and customer service period!!(734)676-9600
Gen5Diy.com.....http://www.gen5diy.com/
Wretched Motorsports..www.wretchedms.com/
Pedders USA
...http://www.peddersusa.com/
bajamoon is offline   Reply With Quote
Old 12-23-2012, 09:10 PM   #3
Vinz68
Vinz68's Avatar
I traded the car in last year to my local dealer the owner kept the car and put 80 miles on it ...... I bought it back the other day. The car only has 8890 miles on it. I did a lot of mods to the car originally. Make's 635 to the wheels. Maybe he messed it up...... Either way I gotta fix it. It never did it before. Gonna get it on a lift this week to check it out. Ordered all new polyurethane bushings and Pfadt trailing arms. Hoping this will tighten the car up.
Vinnie
Old 12-23-2012, 09:37 PM   #4
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
mine has backed out the rear sway bar mounting bolts twice now.
-John S.
grocerygetter is offline   Reply With Quote
Old 12-23-2012, 09:40 PM   #5
bajamoon
bajamoon's Avatar
Damn hope he didnt mess it up. Get it on the lift like you said and check it out. Good luck
My Build Thread
Pedders USA
Old 12-23-2012, 09:43 PM   #6
Vinz68
Vinz68's Avatar
I hope that's all it is. Thanks!
Vinnie
Old 12-23-2012, 09:44 PM   #7
Vinz68
Vinz68's Avatar
Thanks!
Vinnie
Old 12-23-2012, 10:20 PM   #8
grocerygetter
instigator
could also be that the rear alignment is out. May get a 4 wheel done and check all suspension bolts...ya know...the free/maint. stuff.
-John S.
Old 12-24-2012, 12:01 AM   #9
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
Time for cradle bushings pal problem solved.
L99CAMA2011 is offline   Reply With Quote
Old 12-24-2012, 10:36 AM   #10
Vinz68
Vinz68's Avatar
Just ordered new bushings and trailing arm's as well. Thanks!!
Vinnie
Old 12-24-2012, 10:46 AM   #11
Enough
Drives: 2013ZL1
The car might have broken off a sway bar mount from the lower control arm. Common issue and easily repaired. Once it's up on a lift and you look around you should be able to spot something.
Enough is offline   Reply With Quote
Old 01-13-2013, 12:19 PM   #12
Vinz68
Vinz68's Avatar
It seems to fixed!! We installed Pfadt control arms,toe rods, bushing kit and sway bar end links. Put in Hendrix axels and got a 4 wheel alignment. Car def seems better.
Vinnie
Old 01-13-2013, 12:21 PM   #13
Stitch
Stitch's Avatar
Drives: SS, CTS & SRT-4
I would have bet it was your alignment, but no better to upgrade a few things too!
Glad your problem is solved!
Stitch is offline   Reply With Quote
Old 01-13-2013, 12:38 PM   #14
Vinz68
Vinz68's Avatar
Thanks!!
Vinnie
