Old 12-01-2011, 07:20 AM   #1
jbob1981
Drives: 2011 1SS/RS
Solo High Flow Cats
My car is bone stock right now (L99), but I am getting ready to do a few mods over the winter. I've decided to get the solo-high flow cats and either a cat back or axle back exhaust.
Right now I'm leaning towards Solo's axle back, because I'm not sure the cat back will add much more sound then the axle back, and I can save a few hundred bucks. Am I thinking in the right direction? I would like to avoid doing a tune so that I have a fighting chance of keeping my warranty.
jbob1981 is offline   Reply With Quote
Old 12-01-2011, 07:59 AM   #2
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
i went with solo hiflos and corsa catbacks. i did the catbacks first and decided i needed a little more growl and added the hiflos...sounds just right now.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 12-01-2011, 09:12 AM   #3
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
It is recommended to tune out the rear o2 sensors with hi flows, but many people have had good luck without tuning them out and using alternate methods. Neither the catback or axleback require a tune.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 12-01-2011, 10:05 AM   #4
jbob1981
Drives: 2011 1SS/RS
Solo claims on there website that no tune is needed.
Is there any reason I should get a cat back instead of an axle back to go with the high flow cats?
Old 12-01-2011, 11:20 AM   #5
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Don't think it has anything to do with HF cats, but a catback on an L99 will get rid of that big, honkin' resonator and likely replace it with an X-pipe depending on which kit.
Old 12-01-2011, 12:47 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The PCM will adjust for the added airflow but in many cases will throw a CEL with the cats. Some have had luck and didn't throw a code but many haven't been so lucky.
If you're staying with a 2.5in system, you can do either. The catback will in most cases be mandrel bent where as the OEM is pressbent. It's not really that big of a deal since there aren't any BIG bends in the system. Performance wise, there's no difference. A catback will also replace the huge resonator/H pipe section on the L99. If you go with a axleback, you can have a muffler shop cut out that section and replace it with a X pipe. This car NEEDS a crossover or it will lose HP and tq. A Magnaflow true X pipe runs around $80. Any muffler shop will be able to do the work for less than $100.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 12-01-2011, 01:03 PM   #7
jbob1981
Drives: 2011 1SS/RS
Doesn't that big honkin' resonator help reduce the AFM noise when it kicks on? That is another reason I was thinking an axleback may be better. I know I'm going to hear the AFM no matter what, but I was hoping to keep it at a minimum.
Old 12-01-2011, 03:31 PM   #8
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
my personal recommendation is to put on the solo hi-flows first and leave the stock exhaust on. I have an LS3, so my exhaust is different, but dang it sounds so much nicer with the Solos. I don't even feel like I need to upgrade the exhaust anymore. The only reason I would might be to change the tone, because with the current setup I have no drone and it's several times louder at WOT.
I also have not heard of one case on Camaro5 where a person installed solo high flow cats and threw a code... other brands, yes. But not Solo.
cab2g is offline   Reply With Quote
Old 12-01-2011, 03:38 PM   #9
tylerSS
Drives: 2010 Inferno Orange SS 6spd
5k miles with solos/AMT catback and no CEL for me....sounds awesome
tylerSS is offline   Reply With Quote
Old 12-01-2011, 03:40 PM   #10
Juiced1
Drives: 2012 2SS CAMARO 45th
Either way it will sound good. The only thing I would mention is that if you change the axleback you won't be able to find a mid pipe that bolts up down the road. So if you even add some big power you'll still be running the factory H-pipe which might cost you some power. If you don't plan on getting to crazy with it the axleback should be just fine as the stock catback doesn't have much restriction at all.
Juiced1 is offline   Reply With Quote
Old 12-01-2011, 03:40 PM   #11
Juiced1
Cab2g has a good idea to. You can always run just the cats, you'll be surprised how good that sounds!
Old 12-01-2011, 06:34 PM   #12
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
I added the Solo Hi-flows first, really opened up the sound. No CEL. Had that on for about 4 wks, then added the Solo Mach XL catback. Wow, that really adds a much deeper note to the exhaust. Sounds great. No CEL.
Love me some Solo.
hrpiii is offline   Reply With Quote
Old 12-02-2011, 06:51 AM   #13
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
Hi Guys, we worked long and hard to keep the CEL light out when it comes to the High-Flow Cats. We're glad that you're enjoying our efforts! Thanks so much for the feedback and feel free to call if you have any questions etc.
GOINGSOLO2 is offline   Reply With Quote
Old 12-02-2011, 08:49 AM   #14
jbob1981
Drives: 2011 1SS/RS
Well I think I go with cats first, see how it sounds and then go from there. Are they something I could istall myself or should I let a shop handle it?
E85 TUNE RESULT!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 327 10-13-2011 06:22 PM
JBA High Flow Cats + ?axle back exhaust? NORSS426 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 02-26-2011 10:28 AM
Solo High Flow Cats Fishdadddy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 12-04-2010 03:47 PM
Brand New Solo High Flow Cats for LS3 ddavis V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 14 08-10-2010 10:23 PM
NEW High Flow Cats COMING SOON from SOLO Performance GOINGSOLO2 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 414 07-24-2010 05:55 PM
