Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 03-13-2024, 02:54 PM   #1
Whitlow
Whitlow's Avatar
Drives: Chevrolet Camaro
PLEASE HELP IS IT MY BCM???
Hello everyone,
My 2012 Camaro ss the high mount brake light stopped working so I bought a new one went through everything to replace it. Plugged it up and still no high mount brake light. What could it be there is not a fuse for it or the other brake lights. I read that the bcm operates it so I checked all the fuses for the bcm 1-8 and all the fuses are ok. PLEASE HELP I don't know what to do!!!!
Thanks
Whitlow is offline   Reply With Quote
Old 03-13-2024, 03:49 PM   #2
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
Bad BCM, broken wiring, bad ground, bad light socket are all possible and probably a few more. Bad BCM is probably the least likely. Going to take some diagnostic testing to determine what is actually the issue.
gtstorey is offline   Reply With Quote
Old 03-13-2024, 05:43 PM   #3
bsn
Drives: 2013 ZL1
Try disconnecting your battery and shorting your cables together.
bsn is offline   Reply With Quote
Old 03-14-2024, 04:31 PM   #4
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Check fuse F33 (20A) in the underhood fuse block. Check for power on the White wire at the high mount connector and ground on the Black.
Mouse330 is offline   Reply With Quote
