Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 12-31-2015, 08:05 PM   #1
YoungMulaBaby
Drives: Camaro 2014 2LT
Door chime going off? Help!
For the past few days, my remote key fob (I hadn't gone to the recall) wouldn't let me lock the doors, unlock the doors, open the trunk, nor let me remote start. I didn't press the alarm sound, figured it was too risky. Also, everytime I opened the driver door, the chime would turn on. The only time the chime stops is when the door is closed and the key is in the ignition.
I went to Chevy today, and got the recall fix, but they said they had no idea what was going on, and I'd have to create another appointment. I did the key fob programming, which didn't work whatsoever. I tried lubricating my new key and inserted it into the ignition switch in hopes, it was the ignitions problem but nothing.
What's going on? Help!
YoungMulaBaby is offline   Reply With Quote
Old 01-04-2016, 05:14 PM   #2
YoungMulaBaby
Update: Fixed it.
Issue:Turns out the car kept thinking there was a key in the ignition key, thus neither the remote nor the driver door could be locked (without physically locking it). The flap was stuck.
Solved: Lubed up the key and w/ tweezers got the key flap to act right.
Old 03-19-2020, 03:26 PM   #3
D0NTSURF
MASTER SHREDDER
Drives: 2014 Camaro RS
I'm stoked that you took the time to put this post up! I'm having the exact same issue. I thought that might be the case with the ignition thinking the key was still in, but I messed with it so much putting the key in and out and jiggling it that I gave that up as a solution. Gonna try the lube and see if that will get it. I'll report back and let everyone know if this works.
D0NTSURF is offline   Reply With Quote
Old 09-02-2020, 04:31 PM   #4
tomdarrohn
tomdarrohn's Avatar
Drives: 2015 Chevy Camaro RS
Smile Saved my day again!
Thanks so much for posting this. Not sure how much money you just saved me, but sure enough, that was my problem. Same exact symptoms. I took a look at the ignition and sure enough the little cover was stuck. I put some lube on the key, ran it through a few times, then jiggled it a bit and the cover slid back into place. Now the remote works, door doesn't chime without the key in the ignition and life is good. This website has probably saved me thousands on other issues I have had as well!
tomdarrohn is offline   Reply With Quote
Old 10-15-2020, 07:06 PM   #5
DetroitBadboy
Just a guy enjoying t
DetroitBadboy's Avatar
Drives: Chevy camaro lt
Send a message via AIM to DetroitBadboy Send a message via MSN to DetroitBadboy Send a message via Yahoo to DetroitBadboy
I just saw this thread. I have tried everything possible to figure this out. Ten min and a bit of lubricant......fixed. thank you so much whomever figured this out. Genius
DetroitBadboy is offline   Reply With Quote
Old 10-15-2020, 08:55 PM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
Lube is your friend.
Vegas Bound is offline   Reply With Quote
Old 02-17-2022, 02:11 PM   #7
pcguy2u
pcguy2u's Avatar
Drives: 2009 Corvette ZR1
Where is the flap located? Is it visible? Does the lock need to come out? Can't see where the lock is released???
TIA, Nick
Here's a link to my 70 Chevelle build thread:
https://www.chevelles.com/forums/12-...aro-donor.html
pcguy2u is offline   Reply With Quote
Old 02-17-2022, 02:52 PM   #8
TooCool5
TooCool5's Avatar
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP
Mine chimes sometimes after I start and drive down the road.
It was the door electrical connector, had moisture in it.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
TooCool5 is offline   Reply With Quote
