Old 11-17-2015, 12:23 PM   #15
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
I've driven both M6 and M7 on Corvette and I much like an M6 power delivery better than M7. In M6, each gear seem to be a bit taller and hits the sweet spot on the RPM.
Z_Rocks is offline   Reply With Quote
Old 11-17-2015, 12:35 PM   #16
bhavyas
bhavyas's Avatar
Drives: 2016 1SS Yellow
Originally Posted by KaBoom1701 View Post
Too many gears....
All you need is 6.
Most Stingray owners will admit that rowing 7 gears is a little much.
Completely agree with this one.. 6 is perfect... if you are talking about occasionally wanting higher MPG... switch to higher gears faster and then stay there... Dont expect the Camaro V8 to give you a civic type mileage.. its not built for that..
bhavyas is offline   Reply With Quote
Old 11-17-2015, 12:49 PM   #17
jimmypop13
Drives: 2016 camaro ss
Originally Posted by Bhobbs View Post
It's not bizarre. AFM increases engine vibrations so they have to deal with that. The torque converter on the autos help. The Stingrays use iron torque tubes to absorb the vibrations which is why they can use it with the M7s. The Camaro manual bolts to the engine so the same set up won't work.
I'm curious how bad it gets when you add long tube headers. I was definitely planning on doing this to my 2016 camaro when I get it. I have hp tuners so I guess I could disable afm if it was that bad
jimmypop13 is offline   Reply With Quote
Old 11-17-2015, 01:08 PM   #18
01Camaro
Drives: 2001 Z28 Mn6
Originally Posted by Nicul15 View Post
the EPA ratings have changed since then. so
if the sticker says 28 on your 4th gen and this car says 26 mpg this car should get the same or more. 455hp vs 350hp.
just really bizarre they disabled AFM on the M6
Interesting..did not know this. Thanks. When I lived in flat flroda, I would often lock into 6th and get 30+ MPG.
01Camaro is offline   Reply With Quote
Old 11-17-2015, 01:11 PM   #19
daytonagary
daytonagary's Avatar
Drives: 1932 Ford 3 Window Coupe
Too many gears....
All you need is 6.
WRONG..... Love my 7 speed in my C7 Corvette and so do all C7 owners I have discussed this with. Geared perfect and love traveling the interstate at 75MPH at only 1450 rpm getting 32 MPG. Driving around town perfect too. If I want to just "grandpa" it around town my rpm is always 1200 to 1400 rpm shifting into3 rd at 20mph, 4th at 30 mph, 5th at 40 mph, 6th at 50mph and 7th at 60 mph. Perfect match gearing for the low end torque of the 455 horsepower engine. Will pull strong at 1200 rpm in any gear. When I want to let it rip or just take a more sporty afternoon drive, just pick a lower gear and let the rpm rise. Will be getting a new Camaro next spring and only thing I don't like so far about it is the lack of a 7th speed and the heavier weight of the car compared to the C7 Corvette and compared to all the muscle cars I grew up with in the late 60's.
daytonagary is offline   Reply With Quote
Old 11-17-2015, 01:36 PM   #20
01Camaro
So it looks as if the 6 speed, under the same rating system as my 2001 would be rated at +2 for highway and city, so 18 and 27 mpg, which would be very close to my LS1's ratings. That could help me make the decision to pull the trigger.
Old 11-17-2015, 02:03 PM   #21
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
The C7 never had an M6, so if you are comparing the C6 to C7 you are talking about two different engines, transmissions and gear ratios. Hard to compare exactly...but I agree, 6 gears is the perfect amount.
Old 11-17-2015, 02:20 PM   #22
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Just as we have now ^ seen a defense of the M7 in the C7 there are a number of posts on the Corvette Forum deriding the M7. The derision seems to be based on the gearing, which we see from the above is also defended.
In the end, as currently designed, the M7 does not fit the Camaro.
Laborsmith
laborsmith is offline   Reply With Quote
Old 11-17-2015, 03:17 PM   #23
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
lol...ok?
You admit to owning a C7 and getting 32mpg......
I guess if you want to drive the car like a grandpa then the 7 speed is the perfect tranny then. lol
More gears in the automatics is the way to go. Manuals I'd say are good at 6. The extra gear is nice for mpg ratings as you said but that's about it.
I've been a passanger in a 8sp auto Z06/07 and Chevy did an outstanding job with that tranny. I'd almost get that verses the 7spd manual if I was lucky enough to order one. I don't think you can out shift the new 8spd auto in the Z06/07 cars. IMHO
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 11-18-2015, 05:57 AM   #24
1hevy_chevy
1hevy_chevy's Avatar
Drives: Nightfall Gray 2016 6M 2SS
I don't think 7 gears would feel quite as powerful anyway
1hevy_chevy is offline   Reply With Quote
Old 11-18-2015, 06:52 AM   #25
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Just bring back the 4+3 transmission from the c4. Only shift 4 times yet get 7speeds. Win-win...
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 11-18-2015, 12:28 PM   #26
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
Much cost for little gain.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 11-18-2015, 01:14 PM   #27
daytonagary
M7 vs M6
WRONG... M6 in C6 Corvette and M7 in C7 Corvette have the exact ratios from 1st to 6th gear. 2.66 first, 1.78 second, 1.30 third, 1.0 fourth, .74 fifth, .50 sixth. You will notice no difference in driving the two since there is absolutely no difference. Only advantage to 7th gear is gas mileage on interstate which I like on 8 to 10 hour driving days on the interstate which the .42 ratio provides. The Camaro uses lower gear ratios because of the heavier car but again, if it had 7th gear, I am sure the first six would be identical to 6 speed since they have done that in the vette. But it won't fit so it is a mute point anyway. The high performance Corvette's use gearing similar to the Camaro and have a 2.97 first, 2.07 second, 1.43 third, 1.0 fourth, .71 fifth, .57 sixth and .48 7th.
Old 11-18-2015, 02:02 PM   #28
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Well, I should have looked it up before I posted it had an additional underdrive. Three overdrive gears should help FE, too bad the TR6070 won't fit.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
