02-27-2017, 08:53 AM | #1 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Smartest way to 600hp?
I've got a stock 2013 2SS with an L99. The only mod I've done is Flowmaster super 10's. This summer I'm planning on a big power jump.
You guys know better than me, but can I get 600hp with just bolt ons? And can the stock tranny and rear handle it? |
02-27-2017, 08:56 AM | #2 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
600 with just bolt ons wont happen.... What is your budget?
supercharger and turbo aren't usually considered bolt on's...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi Last edited by racesloth; 03-02-2017 at 04:03 AM. |
02-27-2017, 09:02 AM | #3 |
Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
L99 you won't even get 500 with just bolt ons.
02-27-2017, 09:25 AM | #4 |
Hmmmm. So all these bolt on supercharger and turbo kits don't even give 100hp gain? I'm really not concerned about the cost. I'm looking for the most reliable, no nonsense way to go about this.
02-27-2017, 09:43 AM | #5 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Supercharger or turbo.
I'd budget $2000-2500 for a trans rebuild too.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
02-27-2017, 10:03 AM | #6 | |
Drives: 2011 2SS Join Date: Mar 2015
Most people wouldn't say superchargers and turbos are "bolt ons". Either of those options will get you what you're looking for though. There are lots of threads on here that will show you what other people have done to get to 600 horsepower
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
02-27-2017, 10:38 AM | #7 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
OPTION 1:
Twin turbos from AGP, can leave the stock engine alone and get there -- since you've not modified anything. OPTION 2: I have the ADM LSA Supercharger that is very close to 600 RWHP, and with a pulley upgrade, can get there. You have an L99, so, you'd have to consider a cam upgrade, lifters, and since you've pulled the heads, a CNC ported set GMPP or from GPI. For either option: There are other mods too -- suspension, fueling, headers (if you go supercharger), Catch cans (Mighty Mouse is the one I've used for my FI build), CAI choices, tune. You really should get a plan of what you'll need to 'support' 600 RWHP -- its not just bolt ons or turbo/supercharger. There are several other items that need to be addressed in order to handle that increase in power. I've done a lot of those, and it was a long term plan after I decided to go FI. I did the usual bolt ons, then focused on suspension. After those changes and increasing the power via supercharger, I did other suspension mods that I discovered while road racing. There are other items to consider, cooling (trans, radiator, engine) that also play into this. I added a ton of cooling to the system to handle the heat generated as well as my future goals (ported supercharger/snout/pulley). I'm also having to upgrade fueling as I go. The bug will hit you once you start ;o) My suggestion is read the Members Build thread -- LOTS of info on what folks have done. It will be an eye opener once you get into it. -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
02-27-2017, 10:58 AM | #8 |
Drives: 2011 Camaro 2SS/RS L99 Join Date: Aug 2013
stock L99 trans can handle up to 700 crank hp I believe
Stainless Power Headers, High Flow Cats, CAI intake, SLP Loudmouth 1 exhaust, Dyno tune from Alternative Performance |
02-27-2017, 12:01 PM | #9 |
Drives: Black L99 2SS/RS Join Date: Mar 2014
Just get a ZL1.
Even if you sell your car for $15k, for an additional $15k you can get yourself a used ZL1. Let's say you really want that 600rwhp. So you spend $7k on a twin turbo kit. Then another $1000 for install + tune That's $8k right there. You're already at $23k (with the $15k car) Now you have 600rwhp. You're probably gonna need to spend an additional $2k for suspension + install to have the power actually be put to the ground instead of skidding at around everywhere. Then bigger brakes + rotors an easy $500 - $1,000 So you're already at $25k. I mean we're just talking in terms of getting to 600rwhp. Not sure how the stock drive train will hold up But if you wanted to upgrade tranny or internals, an easy $2k - $3k is in your future too. So if you do the math, a ZL1 is still an easier and much safer option to 600rwhp. You can safely hit 700rwhp and the car will drive stock, unlike a crazy tricked out SS which at 600rwhp, will definitely not drive stock. |
02-27-2017, 12:02 PM | #10 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
For a short time.
OLD GUY FLYING FAST AND LOW
02-27-2017, 12:42 PM | #11 |
Thanks everyone for your input. I see it's best to develop a plan that takes into account the handling, cooling and fuel delivery too. The Brembo brakes feel pretty strong to me but I will consider them too.
02-27-2017, 12:49 PM | #12 | |
There's some people daily driving 600rwhp... some, not many. But they've done just fine without too many issues if I remember correctly, but you have to take into account how much they spent getting there. In my humble opinion, forced induction is overpriced in terms of inflation and adjustments now. These cars are now worth less than half of what they cost brand new 4-5 years ago. ZL1's brand new were $50-$60k for 5th gens. Now they're low-mid $30's. Superchargers and turbos are still the exact same price they were 4-5 years ago. I'm no financial expert and I can't say that their prices aren't deserving, I just think in terms of how I feel when you consider $ - Horsepower ratio and what you can buy now with X amount of dollars, versus what was available back then. |
02-27-2017, 08:32 PM | #13 |
Drives: Nsrt & Camaro SS Join Date: Nov 2014
Or..... You can go big cam some ported heads and Nitrous. Best way....
02-27-2017, 09:21 PM | #14 |
Drives: Camaro Join Date: Mar 2013
It's a toy, spend your money the way you want and enjoy it. You can't take it with you. I've spent more on mods than my car cost and I'm not done yet.
