Old 04-11-2016, 06:10 PM   #1
rydahog
rydahog's Avatar
Drives: camaro ss
tires inside camaro..
Will 4 base camaro tires on rims, fit inside a camaro for transporting them.? Thanks
rydahog is offline   Reply With Quote
Old 04-11-2016, 06:15 PM   #2
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
They should. I've fit 20x10.5 with 285/35 inside the car before. Needed the passenger seat though.
Jenner is offline   Reply With Quote
Old 04-11-2016, 06:50 PM   #3
rydahog
rydahog's Avatar
Drives: camaro ss
yes,,,i was thinking one trunk....2 in back seat area...and 1 in pass seat...does that sound right?
Old 04-11-2016, 06:53 PM   #4
speedzalot
speedzalot's Avatar
Drives: 2011 Camaro SS
I don't think you can fit 1 in the trunk with tire mounted , the trunk opening is small .
speedzalot is offline   Reply With Quote
Old 04-11-2016, 06:54 PM   #5
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
I did just that a while back , two 20x9 in individual boxes on the trunk , I had to put it through the back seat , ten close the seat back up to its normal position
Then I put the Oder two in their boxes also on the read seat , then we went in to a 200 + miles one way drive
Jackass is offline   Reply With Quote
Old 04-11-2016, 07:00 PM   #6
rydahog
rydahog's Avatar
Drives: camaro ss
tires in rear?
HI,,i need to know with rims and tires? will they fit? thanks no boxes//
Old 04-11-2016, 07:23 PM   #7
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
spike III Build IBM 1SS/RS [COTW] 6/25/12
Yes you can I put a full size spare in the trunk every time I go out of state.
BLU DUCE is offline   Reply With Quote
Old 04-11-2016, 07:50 PM   #8
Mcgin014
Drives: 2014 Camaro
I had 4 tires shipped to my house 2- 245/45/20 and 2- 275/40/20 in the car with a set for sway bars and front and rear brembo brakes calipers and rotors. All in the trunk and back seat folded down.
Mcgin014 is offline   Reply With Quote
Old 04-11-2016, 07:55 PM   #9
chevyracingfan
chevyracingfan's Avatar
Drives: 2018 camaro ls 1le
they will fit feed one into trunk thru back seat area .I fit 4 19 inch and extra spare without using front seat
chevyracingfan is offline   Reply With Quote
Old 04-11-2016, 08:12 PM   #10
WeflyhereSS
WeflyhereSS's Avatar
Drives: 2012 Black on Black Camaro 2ss
Dope question I'm getting mrr 228 n a few days and need to transport to tire shop put on thanks guys
"How do u keep it under the speed limit? YOU CANT HAHAHAHA"
WeflyhereSS is offline   Reply With Quote
Old 04-11-2016, 09:59 PM   #11
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Yup, when I bought mine in California, drove back to AZ, folded down the back seat, and loaded up a carry-on suitcase, two 285/20's a stock air box, car cover, and still had room for another tire.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-11-2016, 11:31 PM   #12
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I was able to transport 4 Blizzaks in my car to the shop for install.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 04-12-2016, 07:27 AM   #13
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
They fit. I had one on the trunk 2 in the back seat and one in the pass seat.
Thor142 is offline   Reply With Quote
Old 04-12-2016, 09:29 AM   #14
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
If you're over 6' tall its pretty comical . My friend bought 4 snow tires for his RS last year . With all 4 tires in the car and the 2 of us I ended up driving because he couldn't fit behind the steering wheel . I was laughing my ass off .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
