01-20-2018, 09:30 AM | #729 | ||
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I keep citing the third 10Best but you can find the same sentiment in any Alpha Camaro review. The chassis is one of the best in the world. Not the tires. It’s Camaros,not 1LE The simple truth is GM cares more about chassis dynamic and that’s been evident for several generations. Ford half asses it.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
01-20-2018, 09:31 AM | #730 | |
Drives: E92 BMW M3 Join Date: Oct 2012
We get it dude. It just isn't SO impressive to people who are not fanboys. Its a great car no doubt, but is not faster than the cheaper 1LE. Cooler for sure, but we are talking performance only.
J-Rod Built and Matt@FSP Tuned Last edited by ST1LE; 01-20-2018 at 09:43 AM. |
01-20-2018, 09:36 AM | #731 | |
Drives: 2017 2SS M6 Join Date: Apr 2017
01-20-2018, 09:37 AM | #732 | |
I used to be Dragoneye...
"Ford builds engines, GM builds cars." And if you really pay attention, you see it in almost every circumstance. And yet...this is also why Ford sells more Mustangs...the buying public-at-large wants a cheap V8, and they don't realize how horrible the chassis/handling is in those models, because they've never driven one of the better ones. |
01-20-2018, 10:00 AM | #733 |
Drives: 2013 GB GT Join Date: Mar 2016
alot of praise and bashing going on about chassis when nobody has any actual data to back up those claims.
S550 chassis is garbage because its less what than alpha? and please include hard data in support. |
01-20-2018, 10:18 AM | #734 |
Good grief. Pay attention man! There are years of professional reviews including this recent head to head saying a the Performance Package 1 is like sitting on a stack of phone books on top of a water bed. Performance Package 1!
01-20-2018, 10:22 AM | #735 | |
When reviewers compare the GT PP1 to sitting on a stack of phone books placed on a waterbed you still require more proof. I can tell you I have owned both 6th gen cars. The Mustang is sloppy, loose and feels like driving on marshmellow. The Camaro is so much stiffer, more responsive, and feels so much lighter it is night and day. If you think the S550 is so good, go buy one. Get rid of that S197 and experience it for yourself. Tell us you're happy to spend 43k on a stripped down PP1 or 50k+ for a premium PP2. |
01-20-2018, 10:30 AM | #736 | |
It's not a matter of less/more. That's too simplistic of thinking...If that were the case, by now, 100+ years after the automobile was invented, every RWD car would be identical underneath. No, it has everything to do with suspension geometry and design, coupled with component quality, stiffness and rigidity, and properly tuning all of these factors together for the purpose the car was meant for. The current Mustang chassis may not be inherently "bad" in design, obviously the GT350 can handle alright...but Ford is clearly not working very hard to make the entire lineup the best it can be. Whereas the Camaro Team has purposefully integrated each of those aspects above in every trim level to varying degrees, Mustang team seems to be happy with saying "That'll do", except for the most expensive models. And even the GT350 is an extremely difficult car to align properly...though Ford (and the other manufacturers) sets their cars up real nice for the magazines, so they never know any better. Finally, I'll say this: The Gen SIX Camaro is the pinnacle of handling and suspension engineering that GM has accomplished thus far. It started in 2010 with the Zeta II Camaro SS. It was "ok", like everyone is accusing the Mustang of being, now. So...two years later, they used ZL1 development to redesign the stabilizer bar placement for better results - and this resulted in improvements across the entire lineup. One year after that, they upped the bar again using some very simple but effective changes to the suspension and created the 1LE package. And then they again improved with the Z/28, introducing DSSV dampers, and some hard-mounted chassis components. Each time they did that - they learned something new about making that car go around a track, and feel confident on regular roads. Now, in Gen SIX, with the lighter, better-designed Alpha chassis...all of those lessons learned in Gen 5 are being put to use, and further improved upon. The V6 1LE turns lap times almost as quick as last gen's SS...the current SS is as quick as the old SS 1LE, the new SS 1LE tickles the Mustang GT350, and the Gen 5 ZL1...the new ZL1 outpaces the old Z/28, and the new ZL1 1LE breaks ground where no Camaro has ever been before. The Mustang has no doubt improved...but at a much, much, much slower pace (no pun intended), and the result is what we see here. No excuses about intended targets, etc, mean anything. They owe a little better effort to their customers. The PP1 SHOULD be the way they set up the GT as standard, and hopefully this PP2 is good and can give the SS 1LE a challenge...but they're relying on DOT R tires to do it, not excellence in chassis development. |
01-20-2018, 10:52 AM | #737 |
I asked about the chassis. not the tires, suspension, steering programming. The Gt350 proves what the S550 chassis is capable of and that shows it every bit as capable as alpha given similar tires, suspension, and steering.
01-20-2018, 11:05 AM | #738 |
Drives: 2SS 1LE Join Date: Oct 2011
So is that why the higher HP GT350 with even wider front tires is slower around the track than the SS 1LE?
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
01-20-2018, 11:05 AM | #739 | |
And I agree - GT350R proves the chassis is capable in similar setups at that performance level. The regular GT350, however, is an example that makes my point of Ford "settling" with that car's lower trim levels. And therefore why, in similar setups at lower levels, does it suck so bad? The answer is either A) They got lazy, B) They don't think any of their customers at those levels what a good-handling car, so they settled, C) They allocated their time and money elsewhere in the car, or D) They don't know what they're doing. I doubt "D" is the case, and I don't see any evidence for "C", except perhaps the Voodoo engine. |
01-20-2018, 11:11 AM | #740 | |
Either you are playing Devil's advocate here or you are trolling. Until the PP2 comes out there really is nothing more to talk about here. |
01-20-2018, 11:15 AM | #741 |
Drives: 2013 Camaro convertible 2SS/RS Join Date: Sep 2014
But it takes a 350r to prove it can handle. But that’s a strip down car with no back seat, short cup2 tires, and carbon fiber wheels to do it, yet it’s only about 1.5 sec faster then a SS 1le on the track.
01-20-2018, 11:15 AM | #742 | ||
you may dislike or not understand Fords approach in its packaging and thats fine...I dont either in some respects. |
