09-28-2017, 09:56 PM | #1 |
Drives: Black 2010 1LT w/ SS nose Join Date: Nov 2015
How would you mod with only $400
If you had a stock 2010 1LT and $400 to spend on mods what would get?
09-28-2017, 10:12 PM | #2 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
Well to be honest a varram cold air intake is about all you can do beside a under drive pulley,with out needing a tune. If you can save up more money get headers, tune and be good to go.If you can really save up do the varram cai and headers and tune you will gain a lot more power. Just do what you can afford.
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
09-28-2017, 10:24 PM | #3 | |
Drives: 2013 Camaro SS Join Date: Oct 2016
09-29-2017, 05:00 AM | #4 |
1bad6
Drives: 2010 camaro Join Date: Sep 2017
Vitesse throttle controler, cold air intake, headers, trifecta
09-29-2017, 05:17 AM | #5 |
Drives: Camaro V6 Join Date: Oct 2016
I'd address the timing chain issues before doing anything else.
09-29-2017, 06:50 AM | #6 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
longevity mods being that your in a 7 year old v-6, catch can if not equipped, timing. engine cleaning internals..all maintentance as your most likely not looking for exterior all show mods. Or save to down pay a newer SS.
09-29-2017, 07:20 AM | #7 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Good advise, IMO. If that's all you have to spend, put it toward the balance or maintenance.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
09-29-2017, 08:29 AM | #8 |
Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
Agreed ^^^
Don't start down the path of modding your car if all you can swing is $400. Its a slippery slope once you get the ball rolling |
09-29-2017, 09:00 AM | #9 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
You guys are nicer than me. I was going to tell the OP to open a savings acct.
09-29-2017, 09:24 AM | #10 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
Also keep in mind that many of the parts you need for simple maintenance are a little more expensive and labor intensive than a lot of the "normal" cars out there. Someone mentioned a catch can. For a direct injected engine like yours, this is a big benefit as they tend to have carbon build up, or "coking" issues on the valves. At this point, it's probably already there, but a catch can will slow it from getting any worse. Oil...this is huge on the VVT engines. Don't let the oil life monitor get down to 10%. These things have a way of making oil magically disappear. Then there's things like spark plugs, coil packs. In order to change these out, it requires lifting the intake manifold, so that will require new gaskets. If you don't do it yourself, there's your $400 right there. So, you see where I'm going with this. Not bagging on you for having a tight budget at all, I do too. The point is to keep the thing properly maintained and put off the "go fast" stuff until you're in better position to do so. |
09-29-2017, 10:28 AM | #11 |
Drives: Camaro Join Date: Mar 2013
Make an extra car payment.
09-29-2017, 10:28 AM | #12 |
Instagram: Sangstah
lowering springs and intake?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
09-29-2017, 03:46 PM | #13 |
Drives: 2012 Camaro 2ss Join Date: Aug 2017
Get a civic
09-29-2017, 04:27 PM | #14 |
Drives: 2014 2SS blue Join Date: Jun 2016
Put $400 worth of gas in it and drive it for pleasure.
