07-10-2017, 11:39 AM | #1 | |
Drives: 2013 Camaro SS and 2016 Camaro SS Join Date: Jun 2014
How it Works: Hurst Line/Loc - Roll Control Kits
Application: Universal and vehicle-specific kits available. Part #1745000 - Hurst Universal Roll Control Kit Part # 5671518 - Hurst Roll Control Kit for 2010-2015 Camaro Features of the Hurst Line/Loc Kits: Used primarily in drag racing to provide positive locking action to the front wheels of race cars, reducing the chance of "Rolling the Lights" and producing more effective "Burn Outs" for heating up the tires. Rigorous testing has proved a 1/100,000 of a second release time and vibration tests have seen up to 30 G's applied without mechanical failure. Adaptable to most domestic and import hydraulic brake systems. CAUTION: Hurst Roll Control should not be used as an emergency brake, or for any application requiring the solenoid to be activated for a long period of time. -Advanced quality design stainless steel valve assembly for ultimate corrosion resistance -Fully enclosed epoxy molded electrical coil for reliability -Attractive finned aluminum housing helps dissipate heat -Wider lightweight base provides better mounting stability -150 micron screen filtered ports to prevent contamination -Field serviceable for cleaning or rebuilding For more information on Hurst Performance products, contact our Customer Support team at 707-544-4761 or visit our website, http://www.hurst-shifters.com/ |
07-10-2017, 11:51 AM | #2 |
What does this have to do with 6th generation Camaros? Would be interested in a kit for the 2016+ Camaro.
08-28-2018, 11:16 PM | #3 |
This! Any developments on a ‘16-‘18 specific line lock kit?
08-29-2018, 07:25 AM | #4 |
BAMF SS
You can buy two of the universal kits and make one for your 6th gen?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
08-30-2018, 05:30 PM | #5 | ||
Drives: 2016 Camaro SS Join Date: Nov 2015
- Jason @ Hurst |
Tags |
brakes, burnout, hurst, line/loc, roll control |
