11-14-2016, 09:03 PM | #15 | |
Tri-County Camaro SWFL
Should be good weather for FL. Less than 1000 DA
11-15-2016, 10:54 AM | #16 |
Drives: 14 white Camaro 1LE 2SS/RS Join Date: Oct 2013
11-15-2016, 10:58 AM | #17 |
Drives: 2013 White 1SS 1LE (? of 72) Join Date: Apr 2015
what time are you thinking, not a drinker either but it would be nice to see all the Tampa 1LE's
11-16-2016, 05:22 AM | #18 |
Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
I got EFR 7670 AGP kit with methanol ,850cc injectors! Car run perfect have kit since February, upgrade Bmr bushings( anti wheel hop) drag radials on back-car rides pretty good! Last month upgrade my clutch to triple from Monster , new fuel system from AGP will be here by thanksgiving ( triple e85,flex sensor,rails,1400cc injectors...) . Very happy!
AGP TT 807whp 811wtq 13.46psi E85+methanol
11-16-2016, 11:33 AM | #19 | |
11-16-2016, 12:49 PM | #20 |
Clutch still look fine just pedal start stick to the floor bad! I will let my tuner decide on boost level( he got 1le with ips kit) as soon he done tune on pump and e85 I will update! Here video on dyno https://m.youtube.com/watch?v=rT6MGzhgCVg
11-16-2016, 01:32 PM | #21 | |
nice little video you got there brother! enjoyed watching it. Im so antsy to get this kit, I have been holding off on getting it for so so long. Its just a lot of dough to drop at once. |
11-16-2016, 02:03 PM | #22 |
I know, but believe me it's money spend well
11-16-2016, 05:26 PM | #23 |
you ever worry about your bottom end though?
11-16-2016, 05:50 PM | #24 |
"People" say stock ls3 can take 1000hp! My tuner has stock engine and he close to 900! But when it blow soon or later my plan full build long block ( iron block, different heads,cam....everything to get 1300-1500 whp ifew places quote me 25-30k)! Live to short to drive boring cars
11-16-2016, 06:18 PM | #25 |
Drives: 2014 2ss 1le Join Date: Sep 2011
Whats the approximate cost to get to 650 hp?
11-17-2016, 08:35 AM | #26 |
Hard to tell big turbo easy do big power on dyno but less fun drive on street
11-28-2016, 10:19 PM | #27 |
Drives: Summit White 2015 1LE 2SS/RS Join Date: Feb 2016
I have the agp kit. My car makes 650hp/605tq. The car is a lot of fun to drive and it runs great. The clutch I think will be the first to go..just like glushenij my pedal will stick to the floor at times. I'm not running a lot of boost maybe 8lbs. I have a btr turbo cam and the alky meth kit.
11-28-2016, 10:32 PM | #28 | |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Weight is a non issue. Drive train can be upgraded in time, as long as you plan on driving civilly. Look into DSS 1000hp axles and a new rear end, I went with the ZL1. Found a used 323 pumpkin with 10k miles on it for 1200 shipped. Also some different tires, 20 inch drag radials at the least, to start, then preferably 17 or 18 inch wheels and tires. Once the car hooks it will beat on the clutch and rear end more and more. So yes you can get away with the stock clutch, but your on borrowed time. Don't worry to much about the driveshaft, axles and pumpkin are the things that need to be upgraded first. If you plan on being aggressive with the car. As for clutch, go with a dual or triple disk clutch something rated way over what your hp goals are. Bottom end will take 800whp all day, tuned properly and valve train upgraded. Many have gone to 1000 on a stock bottom end, but IMO that's just a matter of time, and usually only done by people who have a fresh one sitting on deck for when it blows up. Honestly the cost of the kit will get you to 1000 on small base turbos, provided you have the fuel and other supporting mods to support it. There are two AGP kits in the C5 classified section, one is used and the other is still new.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
Tags |
1le, agp, turbo |
