12-11-2015, 01:37 PM | #1 |
Drives: 2010 Equinox LF1 V6 Join Date: Jan 2015
New V6 Brake Upgrade option.
Do you have a V6 and want to upgrade your brakes? I recently discovered a new cheap option!
Go on Ebay and search: "ATS Brembos" there are many under $300 options that include pads and hardware. these 4 Piston calipers are designed for the V6 smaller rotors and bolt up without major modification. I only had to trim my dust shield, and reuse the identical mounting hardware from the 1 Piston caliper. |
12-12-2015, 09:26 PM | #2 |
Drives: 2012 1LT SIM Camaro Join Date: Sep 2012
Did they make a substantial difference?
Reason i ask is part of a brake upgrade is usually larger diameter rotors, functions like a bigger lever and greater swept area. I'm thinking hard about upgrading my V6 front brakes in some way. V6 rotor dia = 12.6" SS rotor dia = 14" |
12-13-2015, 11:36 PM | #3 | |
Drives: 11 Camaro V6 RS, 03 BMW Z4 Join Date: Oct 2013
I have been wanting to upgrade my brakes for a long time but I have to make sure everything is going to be flawless because I will buy parts and install them overseas. |
12-15-2015, 12:28 PM | #4 | |
Just unbolt your old calipers, and replace with the ATS calipers with the brembo pads, they use the same bolts, brake lines, etc. you may have to trim your dust shield slightly. then bleed your brakes with the new calipers. buy a set with the pads already installed from the vehicle it came off of for even less steps. |
12-15-2015, 12:44 PM | #5 |
Consistently inconsistent
Drives: 2015 2LT Summit White Join Date: May 2015
I paid less than that for some Brembos, so I don't see what the benefit would be except if you wanted the smaller rotors. If so, then why upgrade? The V6 brakes are adequate for 99% of the people who have these cars.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface. |
12-15-2015, 07:03 PM | #6 | |
I like the Idea of the 4 piston Brembos . And its a nice upgrade with out breaking the bank because you don't need to potentially buy new rims to make them fit . OP do you know if the 18" Heritage steel wheels clear the 4 pot Brembos ?
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
12-15-2015, 10:35 PM | #7 |
I've had dozens of cars with single piston calipers and they didn't have any problems.
The steel wheels won't fit with the Brembos without a massive spacer.
12-16-2015, 12:44 AM | #8 |
I am still holding off, but am very tempted. I have already invested in better rotors and stainless brake lines.
With the smaller cost of the ATS brakes and the fact that I can reuse all of my other performance parts it is really looking good. I still want to see some more facts... I occasionally take my car to the track and last time my transmission over heated before my brakes did, but I was getting A LOT of fade and having to brake a lot harder and earlier after just a few laps. Will these callipers do anything to improve this? Or will it just give me a better brake feel, which is something I have been trying to do since I got my Camaro. The Brembo website also says they are aluminium. Are they lighter than the stock V6 callipers? I also read they are manufactured in the US, is that also true? |
12-16-2015, 08:39 AM | #9 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
I bought a full front/rear set of SS Brembo's, pads, and rotors, for under $400 shipped.
Best thing you can do right there!
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
12-16-2015, 08:40 AM | #10 |
The bigger Brembo set from an SS or CTS-V will help resolve fade by letting you run better larger rotors. Once you get drilled or slotted rotors, you're reducing the rotor surface area- which is like running a smaller rotor. That's why you go BIG if you want to run slotted/drilled.
12-16-2015, 08:44 AM | #11 | |
After all the research and reading for few days here and on line, I think the best impact and least costly upgrade path for us V6 owners is to purchase the complete V8 camaro brembo brake system and install it. Guys have purchased low mileage used SS systems (rotors, calipers, pads, and brake lines) for as little as $500. (the rear dust/debris shield either needs to be cut for clearance, or replaced with the SS piece, better to replace it imo) Then you move to 14" front, 14.4" rear rotor diameter and the 4 piston Brembo calipers. By comparison, V6 rotor dia is 12.6" front 12" rear. And its all bolt on. There are pages and pages of posts here on camaro5 about this swap, great useful info. And there are other more expense options too. 6 piston brembo calipers from the Cadillac CTS-V are available on ebay, which use a 15.4" front rotor. No doubt this is even a more powerful option but its going to cost you more than $1000 for just the complete front setup. And they look way cool too. Really not a bad deal, GM building several heavy high powered vehicles gives us viable options. I think purchasing the caddy 4 piston caliper and bolting it on V6 12.6" front rotor will give you some measurable improvement, but not nearly what the 14" rotor, 4 piston SS caliper will do for you. Members here who have done the full SS brake upgrade front and rear refer to it as "night and day difference" versus their former stock V6 brakes. |
12-16-2015, 08:46 AM | #12 |
12-19-2015, 08:56 AM | #13 |
here is a great article on upgrading braking system to ZL1 system I ran across this morning. It also has test data, before and after. From SS to ZL1 brake upgrade. So to do this upgrade to the V6 models would yield superb results.
http://www.chevyhardcore.com/tech-st...-track-camaro/ Article also has info about proper bedding procedures of new brake pads, which is great info for any pad replacement. |
12-19-2015, 09:26 AM | #14 |
I got used SS front calipers and rebuilt and painted them, got new CTV rear calipers for $100/ea from the dealer and painted to match. Goodridge stainless lines and high end aftermarket rotors- all in, I have maybe $700 in the whole setup and LOVE it. It truly is night and day difference. Only drawback is my donut spare- if I have a flat on the front I have to move a rear wheel to the front and use spare on the back to get home. No huge deal. I don't like to run without a spare since there's no cell service in many places I go.
Also carry a plug kit and fix-a-flat too. My 18" wheels with snow tires now won't fit at all, so gotta sell those off and just had some 19" snows for some 2LT wheels ordered since those 19's fit over Brembos.
Tags |
ats, brakes, brembo, cts |
