03-28-2015, 10:19 AM | #1 |
<< CRAZY BEE >>
Drives: 400HP 2LT/RS Join Date: Apr 2009
Installing Scosche kit and Pumpkin 6.95 4.4.4
Ok guys here is my 2nd major audio overhaul to my car audio.
My first question is do i need to cut off the wire harness on the pumpkin then solder each lead to the scosche harness? Im normally very good with figuring these wires out but am i missing something here? Im assuming wires need cutting regardless. I will update this thread as i go.
CRAZY BEE - IOM 2LT/RS (more) Cosmetic Mods - 24 | Performance Mods - 14 ROTO-FAB CAI - DT HEADERS - CUSTOM 3-INCH PIPE EXHAUST - RES DEL - R-CATS DEL - MAGNAFLOW RES X-PIPE - 91 OCTANE TUNE - FULL ADM KIT - PORTED IM - PORTED TB - PORTED CH - BLACK 3/8 ISOLATOR - TRIFECTA TUNED |
03-28-2015, 10:24 AM | #2 |
<< CRAZY BEE >>
This is the harness piece im talking about. Its a black connector with 12 pins, should i cut this off and solder each wire to corresponding scosche wire?
03-28-2015, 11:11 AM | #3 |
Killer Tomato
I used plug butt connectors. Mine are soldered but unplug so if I use my head unit in another car/truck all I do is plug in the new harness adapter for the vehicle. They have rubber covers. You should be able to get them at any hardware store or automotive parts supply.
03-28-2015, 12:24 PM | #4 |
<< CRAZY BEE >>
The brown key2 wire, does that go to the telephone mute wire on the scosche kit?
Edit. I got one wire left on scosche kit, the brown telephone wire and two possible wires on pumpkin, brown key2 wire and a grnd -12v wire. Not sure which one to use.
CRAZY BEE - IOM 2LT/RS (more) Cosmetic Mods - 24 | Performance Mods - 14 ROTO-FAB CAI - DT HEADERS - CUSTOM 3-INCH PIPE EXHAUST - RES DEL - R-CATS DEL - MAGNAFLOW RES X-PIPE - 91 OCTANE TUNE - FULL ADM KIT - PORTED IM - PORTED TB - PORTED CH - BLACK 3/8 ISOLATOR - TRIFECTA TUNED Last edited by DJ ATOMIX; 03-28-2015 at 12:43 PM. |
03-28-2015, 12:51 PM | #5 |
<< CRAZY BEE >>
O read on google that the scosche mute wire should be soldered to the black 2nd grnd wire on the pumpkin, is that right? The mute wire does say -12v implying ground. I just want to make sure.
Also i just noticed there is a speed sensing wire from the scosche kit, does that supposed to go anywhere?
03-28-2015, 02:22 PM | #6 |
<< CRAZY BEE >>
K guys i will leave the speed vss wire not attached and i attached the phone mute negative to the black ground on tge pumpkin. If anyone whos otherwise please let me know asap.
03-28-2015, 06:49 PM | #7 |
<< CRAZY BEE >>
Got everything plugged in, everything works! But how the heck do i get all those cords tucked back there?
03-28-2015, 07:30 PM | #8 |
Drives: 2020 2SS SGM - Stock for now Join Date: Aug 2013
What is the pumpkin 6.95?
Sent from my iPhone using Tapatalk |
03-28-2015, 08:09 PM | #9 |
<< CRAZY BEE >>
So after 2 hours of trying to get the headunit into the housing i gave up for today. Is there something im doing wrong?
03-29-2015, 06:53 AM | #10 |
Drives: '11 SW 2SS/RS LS3 Vert Join Date: Jul 2013
I'm pretty sure you have to do some cutting to the trim piece to get the 6.95 unit to fit. Bile_Won would be the best to comment as he's done a similar install.
03-29-2015, 04:43 PM | #11 |
<< CRAZY BEE >>
So I got everything in and everything is working good BUT..
My amps no longer turn off, they seem to stay on forever, do they eventually turn off? I have counted at least 30min already and they are still on. Even the stock amp in the trunk seems to be on still even after i open the drivers door and the stereo is off and key removed.
03-30-2015, 11:54 AM | #12 |
Drives: 2017 Z06 / 2012 CTS Join Date: Jul 2013
Lets see some pics, how much trimming did you have to do?
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06 |
03-30-2015, 02:14 PM | #13 |
<< CRAZY BEE >>
It took me about 45min with a regular fine file from a hardware store. Im sure people can do it faster, i wanted to take my time. Once i get this amp turn off thing figuted out i will post lots of pics.
04-20-2015, 09:29 PM | #14 |
<< CRAZY BEE >>
Here it is, finally painted, installed and ive had a chance to play with it, amazing setup far superior to pioneer headunits imo.
