06-22-2017, 09:47 AM | #1 |
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
How many miles to go after gas light comes on?
Just curious...
06-22-2017, 09:51 AM | #2 |
Drives: 2017 1SS 1LE Black on Black Join Date: Feb 2017
Hopefully one more then you have to go..... haha
06-22-2017, 09:54 AM | #3 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Other cars I've owned stated in their manuals that there's about 2 gallons remaining in the tank when the light comes on, but I couldn't find any numerical indicator in the Camaro's manual.
I would not attempt to drive more than 20 miles with the low fuel light/low fuel message on the DIC. You can damage your fuel pump if you drive around too often with low fuel in the tank. The fuel keeps your fuel pump cool. I usually try to fill up when I'm down to around a quarter of a tank. |
06-22-2017, 09:55 AM | #4 |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
I never let it get that low should be a answer LOL, I would say no more then 15-20 miles but not good to run the car on fumes....
06-22-2017, 10:02 AM | #5 |
Drives: 2017 Camaro SS NGM, 2015 Murano Plt Join Date: Apr 2016
The longest I`ve gone was about 23 miles after.
06-22-2017, 10:15 AM | #6 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
This is exactly what I did yesterday / today.
I live 22.7 miles from work and it came on as I parked at the house. There's a gas station next door to work and I filled up coming to work this morning.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
06-22-2017, 10:16 AM | #7 |
Drives: 2020 SHOCK SS 1LE Join Date: Sep 2016
Yesterday my gas light came on and when I filled up it took about 17.60 gallons. So there was a good gallon or so left to go.
06-22-2017, 10:30 AM | #8 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
The way I drive, about .5 miles.
06-22-2017, 10:49 AM | #9 |
From what I've seen, the light does not come on at any specific fuel level...more often when the Fuel Range gets under 45-50 miles (so that could more or less than 2 gallons depending on the computer's calculation based on your driving). That said I've never let the range get under 30.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
06-22-2017, 11:19 AM | #10 |
Drives: 2017 Camaro SS Join Date: Jul 2016
When it says 50 miles to go it is dead on.
2017 2SS Black NPP A8 - 422 HP 427 TQ
06-22-2017, 11:56 AM | #11 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Well mine said about 35 miles to empty before it stopped giving me DTE. Then I ran 4 autocross laps and drove to the gas station and put 19.035 gallons in it. LOL!!! I'm sure the car has some fuel in reserve, but I won't push it quite that far next time.
MJK3888 Instagram Link
06-22-2017, 11:56 AM | #12 |
Drives: 2016 Camaro 1LT V6 MT Join Date: Oct 2016
I'd say you probably have a gallon or 2 left.... I wouldn't push it much more than 20 on mine unless it was absolutely necessary (haven't had to in the past).
Easiest way to figure it out would be let the gas light come on, top off the tank, copy the amount of fuel needed to fill up and subtract that from the fuel tank max capacity. Tells u how many gallons were left in the tank and multiply by your mpg. |
06-22-2017, 12:08 PM | #13 |
Drives: 21 Bronco Join Date: Jun 2012
Remember E stands for empty, not enough for 10 more miles lol
If my light ever comes on, I try not to go more than 10 miles before filling up |
06-22-2017, 12:10 PM | #14 |
Lovin the growl...
Drives: 2018 2SS Join Date: Mar 2017
Happy to say I do not know first hand.
