01-23-2012, 10:21 PM | #1 |
Automotive Designer
Drives: 2011 Camaro 2SS/RS (LS3) Join Date: Jul 2009
Window Tints KEEP PEELING!!!
My window tints on my driver and passenger side keep peeling up!!! I have already had my driver side re-tinted about a month ago. It just now started peeling up, and now so is my passenger window. Both of them are peeling from the lower corner of the window, by the lock. It is currently cold here in Michigan, and I got them tinted back in the summer. Maybe the cold temperature has something to do with the non-adhesion? Im pretty certain the tint film is catching on something in the door/seal when the windows index... But there has to be a way to fix it. I never had this problem on my 2010 2LT. But it keeps happening with my 2011 2SS... HAS ANYBODY ELSE HAD THIS ISSUE??? My tint guy will replace it, as they have lifetime warranty... But thats not the point. I want a FIX!
2011 Camaro 2SS/RS LS3 (SIM/BLK)
01-23-2012, 10:27 PM | #2 |
Drives: '10 2SS/RS, MKIII Supras Join Date: May 2010
Your window tinter may be installing them wrong. Because of the indexing windows, the tint needs to be installed a little further down than usual so the edges don't get caught when the window indexes. My tint has been fine for the last 6 months.
01-23-2012, 10:31 PM | #3 |
Rolling along...
The fix is to find a better tint installer. You need to find one that knows how to tint indexing windows correctly. Also, make sure you aren't getting the cheapest tint out there...sometimes you get what you pay for.
01-23-2012, 10:36 PM | #4 |
Drives: 2010 ABM 2LTRS, E46 330XI Join Date: Jun 2011
Yes it depends on your tint shop and also the amount of time you let it really stick when I had mine installed I basically had to wait three weeks to a month before I could put the windows down and also they have to install it below the edges or it will get caught and start to roll up and lastly every time you open the door the window rolls down a bit which can also cause it to roll up I it wasn't cut to proper length
01-23-2012, 10:36 PM | #5 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
Had mine for a full 2 years now, no issues. Bad install
01-23-2012, 10:37 PM | #6 |
Drives: Silver 1LT 2011 camaro Join Date: Jul 2011
Mine did this on the passenger side. Took it back to him and he fixed it and it hasn't happened since.
01-23-2012, 10:38 PM | #7 |
Sounds like a bad install to me. I got mine done in August and they've been great ever since. We have similar weather conditions down here and my car is exposed to the elements since its my DD.
01-23-2012, 11:10 PM | #8 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Maybe cheap film? I did mine myself with that precut window tint off ebay, back in August, and have had no problems. It's the 5th car I've done using the same sellers tint, my old 04 GTO had the tint on it for 2 years before I traded it in and had no problems.
01-24-2012, 08:18 AM | #9 |
Founder - Michigan FBody
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS Join Date: Jun 2008
I had mine done at DJ's Window Tinting on Gratiot and Stephens. So far so good *knock on wood* but it's only been a couple of days. I made sure they knew the windows index.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed "Gone But Not Forgotten" 2016 Camaro 1LT A8 - "Elmo" 2014 Camaro 1LT M6 - "Cherry Bomb" 2012 Camaro 1LS M6 - "Clifford" Michigan FBody Association http://www.mifbody.com/ |
01-24-2012, 08:33 AM | #10 |
LS3 Black Widow
Drives: 2012 45th 2SS LS3 and 1968 Mustang Join Date: Nov 2011
Get your installer to pay for another installer to put it in if it comes down to that.
01-24-2012, 08:46 AM | #11 |
Just a car guy
Drives: 2016 Durango R/T AWD Join Date: Oct 2011
OP - It does sound like a bad job. Take it back to your tinter and have him install new film. If that doesn't work, a new tinter that knows how to index your windows correctly is the way to go.
Good luck, hope you get it resolved.
2014 5.0 - Ported CobraJet Manifold - SCJ Mono-Blade TB - Kooks 1-3/4" LT Headers - Kooks O/R H-pipe - Custom Intake - McLeod clutch line - Borla S-Type Axle Backs - AED Tuned - 443 RWHP / 388 RWTQ - GONE 05 GT - Sold 03 Cobra - Gone (Never Forgotten) |
01-24-2012, 09:06 AM | #12 |
Drives: 2011 Black Camaro SS Join Date: Nov 2011
Everybody hit the nail on the head. Because of the window indexing they specifically have to heat the bottom up real well when installing knowing that it will be moved slightly multiple times as you get in and out of your car. This is basically 100% proven to be the issue if you are only having problems with your driver side window, as I assume you didn't really have many passengers after getting the tint installed (within 48 hours).
01-24-2012, 09:40 AM | #13 | |
Drives: Camaro Join Date: Dec 2011
WTF! |
01-24-2012, 09:42 AM | #14 |
Drives: 2010 Chevy Camaro 2SS RS Join Date: Jun 2011
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
MRT Louver | 2010-2012 Camaro MRT Rear Window Louver w/ Prop Rod Kit | Free Shipping! | AutoAgenda | Exterior Parts & Accessories | 221 | 03-29-2017 02:01 PM |
MRT Louver | 2010-2012 Camaro MRT Rear Window Louver w/ Prop Rod Kit | Free Shipping! | AutoAgenda | Cosmetics and Lighting Modification Discussions | 45 | 10-02-2012 05:56 PM |
HELP WITH CLEANING WINDOWS | h2oplay | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 26 | 05-09-2011 09:42 AM |
No Power to Driver's Side Window? | 67 Convertible | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 5 | 11-19-2009 04:48 AM |
Window Indexing | Merlin1187 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 07-13-2009 08:07 PM |
