01-23-2012, 12:29 PM | #1 |
Drives: 2012 Camaro 2LS Join Date: Oct 2011
Sport Mode?
Hey guys. I have a 2012 2LS. I have read many forums about how theres a sport mode and you go into it by just putting it in M and not touching the paddle shifters and it shifts for you...but when i put it into M..an "S" didn't pop up it just said M1 and my car just stayed in that...i finally just said **** it and put it back into drive. Did i do something wrong or there is no sportmode????
01-23-2012, 12:34 PM | #2 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
There have been changes made to the various features of tapshift and trans. modes from the original version and most likely that has changed with the 2012's
01-23-2012, 12:35 PM | #3 |
Drives: 2014 BRM 1SS/RS Join Date: Sep 2011
If you see M1 just hold the right paddle for 5 seconds till the "S" appears!! And vica versa to go back in Manual mode!!
2014 Blue Ray Metallic 1SS/RS A Road Warrior |
01-23-2012, 12:39 PM | #4 |
I put mine in S and it shifted for me. Don't touch the paddle shifters and it will shift for you. But I have a 11 and you have a 12, so maybe they changed it?
01-23-2012, 01:35 PM | #5 |
Camaro Owner & Enthusiast
If I put mine in M it shows M6 and will shift much more aggressively. I have an '11....
Something I just realized... if you take M6, the sixth letter from the letter M is "S"... coincidence? |
01-23-2012, 01:38 PM | #6 |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
Is it different on the LS? It says M6? It should say "S" and only say "M6" when you touch the tapshifter and are already in that gear...
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
01-23-2012, 01:39 PM | #7 |
Chu no guat a hasa is?
Drives: 14 Jeep G Cherokee Overland HEMI Join Date: Jun 2011
Mine says S
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
01-23-2012, 01:55 PM | #8 |
Drives: GM Vehicles Join Date: Jun 2010
If you check in the 2012 owners manual it shows in section 9 on pages 28, 29 and 30 how the manual mode works. It doesn't mention anything about what is displayed in the Driver Information Center when this mode is chosen. Normally when the transmission is put into manual mode without the tap shift paddles being used it will choose a more aggressive shift pattern for you. If this is not what happens when you use it, Rambo3, I would have the vehicle checked to make sure everything is working properly.
Jeff Morris, Chevrolet Customer Service |
01-23-2012, 01:58 PM | #9 |
Let's go Rangers!
This. Mine will only say M"x" when in tap shift mode.
01-23-2012, 02:08 PM | #10 |
Drives: 2011 2LS V6 Join Date: Jun 2011
I think the details of this has had various changes over the past few years. My 2011 just reads M6, and if i don't use the tap shifters it does shift more aggressively. Some models have had the display read "S". Mine does not. So, essentially "M6" is sport mode.
01-23-2012, 02:12 PM | #11 |
It looks like the LS models display M6 where the LT models display S!!
01-23-2012, 03:20 PM | #12 |
Drives: '11 2LT/RS IBM Join Date: Jun 2011
I don't think 2ls has a sport mode because don't they get better fuel economy and stuff?
01-23-2012, 03:57 PM | #13 |
It's the same engine as the LT
01-23-2012, 04:00 PM | #14 |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
v6 sport mode | Hollywood2010 | 5th Gen Camaro SS LS LT General Discussions | 7 | 05-21-2011 09:35 PM |
Sport mode with the L99 | Dosin | 5th Gen Camaro SS LS LT General Discussions | 14 | 05-20-2011 08:05 AM |
SOOOO i just discovered sport mode | Jeremeymt | 5th Gen Camaro SS LS LT General Discussions | 112 | 03-11-2011 04:48 PM |
Camaro SS vs Evo X | MAROobsession | Chevy Camaro vs... | 275 | 08-28-2009 03:49 PM |
Final word on Sport Mode, vs 'Drive'???????? | PQ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 08-26-2009 05:42 PM |
