Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 10-18-2014, 05:30 PM   #29
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Originally Posted by 2013 ZL1 #7860 View Post
With mag ride? I have always heard that mag ride was expensive to fix and I wish the ZL1 didn't have it for that reason. Pay to play and 425$ a strut/shock/whatever every 40k is not so bad... IMO a ZL1 shouldn't have 44k miles yet. I have never owned a car that did not have some repair required at 40k
I have 40, 000, what's wrong with driving it?
Sent by a large Hammer.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 10-18-2014, 11:08 PM   #30
Camaro21
Drives: SOLD - 2013 M6 ZL1
Exactly !! I bought it to enjoy, not to let it sit and make payments on it.
Camaro21 is offline   Reply With Quote
Old 10-18-2014, 11:15 PM   #31
JackalopeZL1
JackalopeZL1's Avatar
Drives: 2013 ZL1
I have owned many many cars that needed no repairs what so ever well past 40k miles.. And who ever buys their car should drive it as much as they want
2013 Silver ZL1
JackalopeZL1 is offline   Reply With Quote
Old 10-19-2014, 07:38 AM   #32
hotlap
hotlap's Avatar
40k miles is early for struts IMO. My wife's last Honda went to 150k with only brakes and tires. My 04 GTO needed Struts and radius rod bushings at 80k but otherwise only brakes and tires.
Ronald Reagan -
Old 10-19-2014, 08:32 AM   #33
vatechguy3
Drives: 2014 ZL1 M6
40k seems low to me as well.
Like the OP said, maybe worn a little and a harsher ride, but not blown.
Tony
2014 ZL1 M6
Bone stock, for now!
2001 Z28 M6
!cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB
!4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link
ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance
OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners!
352rwhp and 366rwtq
vatechguy3 is offline   Reply With Quote
Old 10-19-2014, 08:48 AM   #34
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
Higher performance, tighter tolerances, easier to wear out to keep in proper performance. Look at other high end cars, they require replacement of items well before that mileage. Even my sway bushings which perform better than my oe bushings wore out requiring replacement. 44K is early but not out of the question. At least you are not doing a 4K timing belt replacement every 30k miles...
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 10-19-2014, 04:45 PM   #35
cbass
Drives: .
I highly doubt the suspension wasn't worn at 150K. And only brakes and tires? No oil changes huh? No timing belt or accessory belts? No transmission fluid service? No spark pluts in 150K? Seems like you are missing some maintenance items on that list. Usually the motor mounts are shot on a Honda at around 100K or so.
That and Honda is known for having crap automatic transmissions. If you didn't have a failure in a car from 1998 and beyond within 100K miles then you are lucky. That and if you drive in "severe" conditions which is over 90 degrees (or Phoenix where I live) there transmission fluid change interval is every 30K. Ouch.
https://techinfo.honda.com/rjanisis/...999O00132A.pdf
cbass is offline   Reply With Quote
Old 10-19-2014, 04:48 PM   #36
JackalopeZL1
Drives: 2013 ZL1
Regular maintenance is not repair work.
100k for motor mounts is bs.. There are plenty of cars now a days that do not need a darn thing other than oils changes, brakes, and tires for a long long time period..
But on the flip side of that I would not be surprised about the cast of replacing these shocks.. I knew going into this car certain things were going to cost more and that it was not a Honda in regards to cost of ownership. . But hell the smile on my face when I drive it is worth it.
2013 Silver ZL1
Old 10-19-2014, 05:01 PM   #37
cbass
Drives: .
You can call it BS, but it's pretty common. I owned a Honda civic and for it's legendary do nothing to it reputation it was far from it. It has as much work required and repairs as the astro van. Probably a bit more.
Old 10-19-2014, 05:04 PM   #38
JackalopeZL1
Drives: 2013 ZL1
I have bought three new Hondas for the wife.. not a single motor mount needed..
2013 Silver ZL1
Old 10-19-2014, 07:24 PM   #39
wijg
Drives: 97 Vette
I think the other thing to consider is that people tend to expect different things from their Hondas versus a ZL1. I have owned mostly Chevy's and Hondas (plus a Lexus). My Hondas were great, very low maintenance (repair wise). I bought them to be exactly that, reliable transportation. If the suspension was not performing 100%, the odds are less I am going to notice it on the Honda versus a car I bought for the performance aspect.
wijg is offline   Reply With Quote
Old 10-19-2014, 07:30 PM   #40
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
drive it hard, expect parts to wear out faster.
2010SLVRBULIT is offline   Reply With Quote
Old 10-19-2014, 07:32 PM   #41
hotlap
hotlap's Avatar
I put gas it it too. thought we were talking suspension but anyway... I did do the Honda timing belt at 100k as the maintenance manual suggest and change the oil with Mobil 1 and K&N filter every 4000. Honda automatics have a drain plug so I drain and fill it ever oil change. Takes 3-1/2 quarts so I buy it by the case. Her second Honda now has 51k on it also without issue.
The GTO is now at 96k and has had a clutch, brakes, struts and suspension bushings. I've replaced the fluid in the rear once, drained and filled the transmission twice and replace the serpentine belt.
Maintenance IMO but I understand if you see it different. I actually thought it was shitty that the GTO struts and bushing were shot at 80k after the Honda held up so well.
Bottom-line is I keep my cars 10 years so I take care of them and have been fortune that they have been trouble free
Edit: and plugs, wires and air filters. No motor mounts
Ronald Reagan -
Old 10-19-2014, 08:26 PM   #42
cdjnight
cdjnight's Avatar
Drives: 2013 ZL1 A6
Typically a strut is classified as bolting to the spindle as an actual pick up point of the suspension. ZL1 rear would therefore be a shock.
cdjnight is offline   Reply With Quote
blown, struts, zl1
