11-27-2017, 03:41 PM | #1 |
Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
Chevy Customer Service Reps - are you here? are you listening?
I am not enjoying my first interaction with you so far today. My 2016 Chevy Camaro has the known rear end groan. Im planning on leaving it overnight soon to get it diagnosed and fluid changed (since the dealer has to hear it and it can only be heard in the mornings - you would think that if they know this is an issue they would just change the fluid but that is another story). I would do it myself, but Ive already seen where folks have had to go on to have the diff replaced because a fluid change dont fix it - the last thing I want to do is give you a reason to void my warranty on it or make it take longer to get fixed by not having a documented fluid change at the dealer. I asked the dealer about changing the rear axle bolts referenced in TSB 16-NA-399 and was told that they could only change them if there was an issue with them or they work on the rear end and have to remove them as part of the work. '
I am tired of crawling under a $55,000 car on a regular basis and checking them. I'm tired of worrying that the axles will come out from under it if I don't. I have more faith that my 8 year old Nissan Titan with 173000 miles wont break down and leave me stranded at this point (unless I check the bolts regularly). Here's a novel idea - recall them and fix them. Or, at least replace them when someone asks you to. Then, to top it off, the customer service rep I spoke with wanted to know how I came across the information in the TSB because its supposed to be dealer only info. My case # is 8-3595400773 |
11-27-2017, 04:20 PM | #2 |
Drives: 2016 Mosaic Black 2SS, NPP, A8. Join Date: Jun 2016
For the rear groan, last year they replaced my rear carrier. Now, 12 months later it's in the 50s in the morning it's coming back. My service representative told me to schedule it in and they will probably end up replacing it again. The replacement solved the issue even when it was cold out, but it was a temporary solution :(
Good luck! Sent from the mobile client - Forum Talker |
11-27-2017, 04:52 PM | #3 | |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
Did they attempt the fluid change more than once to eliminate the noise? Did they use the correct fluid? The bolt TSB is only relevant for axle removal or replacement so they are correct in saying that. They aren't just going to replace them because you say so or want them to. If you want the new bolts/washers/retainers, break out your wallet, or rip a nasty burnout and hope a half shaft comes loose.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
11-27-2017, 05:54 PM | #4 |
They are going to diagnose the groan when I take it in - I wanted to get everything done at once but they won’t replace the bolts until they fail.
I shouldn’t have to come out of pocket for new bolts. Chevy doesn’t view it as a safety issue so it gets a tsb instead of a recall. What happens when they come apart at speed? Anyone had that occur yet? Had something similar happen on a sxs once and it locked the wheel up (was a cv joint failure though). I’m sure Chevy thought the ignition switches wasn’t an issue either - until it was. Now they are saying it doesn’t affect my vehicle - anyone know if the 2016 verts have the new bolts? Do we pull them out and measure them to confirm that the correct bolts are installed? |
11-27-2017, 06:02 PM | #5 |
Drives: HyperBlue 2SS 6M NPP MRC Nav Join Date: Dec 2015
I've had my car looked at twice. Each time they were unable to validate. I'm very frustrated.
2016 HyperBlue 2SS 6M NPP MRC Nav
11-27-2017, 06:24 PM | #6 |
Drives: 2018 1LE SS "Silver Bullet" Join Date: Jun 2016
I have the same issue taking it back for the 2nd time this week. They have a huge problem and they will not address it for some reason.
11-27-2017, 10:03 PM | #7 |
Drives: 2016 Camaro SS A8 Join Date: Apr 2016
Which fluid are they using when performing the fix for this issue?
11-28-2017, 09:03 AM | #8 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Unfortunately this isn't going to be fixed, the Corvette's have the same thing as well. Is it right, no, but keep bringing it to the dealer and getting frustrated it a waste of time. Mine is doing it again with the cooler weather, goes away after the first 3 or 4 left hand turns.
11-28-2017, 10:19 AM | #9 |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
What causes the groan?
11-28-2017, 10:33 AM | #10 |
Drives: 2016 Camaro 2SS Join Date: Jan 2015
I had my fluids replaced last winter and it helped a little but never completely went away on cold mornings. I took it in again a few weeks ago and they told me that the cold temperatures thicken the fluids in the diff after it sits for a while. Once the car runs for a couple minutes and makes a few turns it brings the fluid back up to temp and the noise goes away.
They did a full inspection and reported that everything was working as designed at that even though I was hearing the noise in the morning, they assured me that there was no evidence of any wear on the clutch plates or anything else. |
11-29-2017, 09:59 AM | #11 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
All the LSD units I have had had a growl when cold, this one is no different. I told my service advisor hoping to get a free flush last oil change, but they told me they had to keep it overnight and confirm the noise before they could do it. I didn't want to leave the car overnight.
