10-22-2016, 02:53 PM | #1 |
Drives: black 2016 2lt :) Join Date: Feb 2016
psi on tires ?
what do you guys have your tires on ? 35 and above ?
10-22-2016, 03:02 PM | #2 |
Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
I try and keep mine, when taking a cold reading (ie when the car has been sitting overnight and you read the psi without any driving) at 35-37 psi.
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
10-22-2016, 03:38 PM | #3 |
Retired from Car mfrs....
Plus or minus 2 lbs of what's listed on the door sill....don't overthink this for a daily driver. Always check cold.
10-22-2016, 03:40 PM | #4 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
with the weather turning cold, my psi has been checking in at 30 to low?
10-22-2016, 03:40 PM | #5 |
10-22-2016, 03:41 PM | #6 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Yep, add air. I had to do the same when the weather started dipping below 40.
10-22-2016, 07:00 PM | #7 |
SABIO
When it was warm.... 37 front and 35 back.
Now with it getting colder I had my BFG Comp2 A/S set at 37lbs all around a few weeks ago. They drop to 32/33 when in the low 40s, but heat back up to 35. If it gets freezing temps I would have to pump in an extra lb or 2.
