Old 01-15-2016, 08:42 AM   #1
ADM PERFORMANCE
Drives: Anything I want
ADM LSA CONVERSION BELT CHART
You asked for it, Here you go
It only took a Year
2010-2012 CAMARO SS ADM LSA CONVERSION BELT CHART
STOCK CRANK PULLEY WITH STOCK SUPERCHARGER PULLEY GATES K061015 0R 1010 IS TIGHT
STOCK CRANK PULLEY WITH 2.75" ADM PULLEY GATES K061010 OR 1005 IS TIGHT
STOCK CRANK PULLEY WITH 2.50" ADM PULLEY GATES K061005 OR 1000 IS TIGHT
STOCK CRANK PULLEY WITH 2.38" ADM PULLEY GATES K060997
2013-2015 CAMARO SS ADM LSA CONVERSION BELT CHART
STOCK CRANK PULLEY WITH STOCK SUPERCHARGER PULLEY GATES K060975 OR 970 IS TIGHT
STOCK CRANK PULLEY WITH 2.75" ADM PULLEY GATES K060966 OR 960 IS TIGHT
STOCK CRANK PULLEY WITH 2.5O" ADM PULLEY GATES K060960 OR 956 IS TIGHT
STOCK CRANK PULLEY WITH 2.38" ADM PULLEY GATES K060956 ONLY
ADM PERFORMANCE is offline   Reply With Quote
Old 01-16-2016, 05:07 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Nice! Trial and error is more fun!
Stock pulleys green belt I use the K061015HD if any one cares. At least this list should be a sticky!
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 01-16-2016, 07:06 PM   #3
Test_Eng
Drives: 2013 1SS RS 1LE NPP ADM LSA CON
Do these sizes work for 1LE also? I thought the 1LE had different sizes.
Test_Eng is offline   Reply With Quote
Old 01-16-2016, 07:46 PM   #4
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
Thanks ADM
1LE should be on 2013-15 list
definitely sticky this
supergt99 is offline   Reply With Quote
Old 01-16-2016, 08:10 PM   #5
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
How about belt length for 9.55 lower, 2.50 upper, 100mm supercharger idler, 50mm lower idler, and your relocation bracket?
68.5 is what weaponx says without the relocation bracket and those same idlers/pulleys. So idk what the relocation bracket adds or takes away from belt length?
Edit:
Since Andy didn't have any input on the subject...the relocation bracket does not change belt length. The correct belt length for this pulley and idler combo is a 68 5 regardless if you have the idler relocation bracket or not.
Thanks,
Justin
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 01-17-2016, 12:11 AM   #6
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
6 rib belt with a upper 2.38 pulley seems like all it would do is slip.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 01-17-2016, 10:52 AM   #7
ttshovel
ttshovel's Avatar
My buddy with a cobra had grooves cut perpendicular to the belt grooves in his pulley. It stopped his slipping but you lose some belt life
Old 01-17-2016, 11:42 AM   #8
hammdo
hammdo's Avatar
Yea! It's a sticky!
-Don
747 RWHP 794 RWTQ
Old 01-25-2016, 09:07 PM   #9
ADM PERFORMANCE
Ok,Another uprade
ADM Performance, LSAConversion.com and Z06 Parts Inc. are proud to announce our 2016 line up of
Supercharger Pulleys by Z Industries and ADM Performance.
ADM Performance called upon Drew Zimmer and his father to manufacturer our new Premium line of
LSA, LT4,LS9, LSA Conversion and Magnusun Multi piece supercharger Pulleys .
Our new lineup will showcase these new benefits of the previous models:
GRIPTEC® MICRO
GipTec® Micro is a micro machining process. Our micro machining capabilities are near limitless and we apply our technology to give the target component the desired friction coefficient that optimizes the safest most aggressive gripping force possible. Our multidirectional machined ridges and valleys offer up more than just maximum gripping force they also act as escape ducts for trapped air and debris further helping in the mating of the target surface and belt. Patent Pending
Belt slip is a very common issue on supercharged components. In fact some units cranking out as much as 14-16 psi can take up to 200hp to drive. Often the drive systems are plagued with slippage issues and builders find themselves moving to noisy cog systems, where belts have shorter life spans, are difficult to find at just any parts store and they can create more heat through the frictional movement of the cogs.
Belt slip isn't always noticeable. Often belt slip is noticed when the system squeals, squeaks or boost falls off. Did you know that naturally the belt can slip a very small percentage even on NA vehicles, one major factor to belts wearing. Belt wrap does play a key factor in minimizing belt movement but when it comes to driving a supercharger is hard to fully eliminate with just surface contact. Systems runing 3.4 upper pulleys can see as much as a 1.5 psi gain when matching size for size puleys.
Whether you are running 6 psi or 20+ psi you are slipping if you are not running GripTec®
Pro's to using GripTec®
• Increased boost and supercharger performance size for size pulley
• Reduce or eliminate belt slippage on the applied component
• Increase belt life from not slipping over and over again
• Eliminate belt squeaks common when shifting hard
Con's
• To much boost for current engine tune. Adjustment may be required.
About ZPE
ZPE Inc. was founded in 2013 but is no stranger to the automotive world. Our parent company Z-Industries was founded in 1984 and Incorporated in 1987. Z-Industries Inc. offers advanced tuning and emissions services to the aftermarket and OEM industry. ZPE offers advanced engineering solutions for applications in both the automotive and the machinery industry. Our new found love for designing and patenting has brought several new technologies to the automotive and machine industry with more to come. Our commitment to our customers is to provide the highest quality components and service possible. Our standards of manufacturing are the highest possible and it shows in everything from the designs and quality of our parts to our custom packaging. We want to offer a quality that just doesn't exist in the performance world outside of ZPE, which is why we will continue to seek and develop new solutions and parts for years to come.
Andrew Zimmer
President
ZPE Inc.
Old 01-26-2016, 11:29 AM   #10
Test_Eng
Will this bolt up to the the existing 2.5" ADM pulley or will I need to remove the snout to press fit this one on.
Old 01-27-2016, 09:52 AM   #11
ADM PERFORMANCE
They fit just fine.
Old 12-17-2016, 08:11 AM   #12
ADM PERFORMANCE
LSA CONVERSION PUMP LOCATION
It has been brought to my attention that many cannot seem to get the pump mounted as it should be.
I am adding the pictures here so that they are easy to access.
Old 12-20-2016, 08:44 AM   #13
hammdo
hammdo's Avatar
Andy, do you want me to update the instructions?
-Don
747 RWHP 794 RWTQ
Old 12-20-2016, 07:36 PM   #14
ADM PERFORMANCE
-Don
That would be awesome.
