Roto-Fab
Old 08-20-2023, 10:08 PM   #1
DavoinShowerHandel
DavoinShowerHandel's Avatar
Drives: 2011 Chevy Camaro 2SS/RS LS3 M6
Forward Lower Control Arm Removal
I've hit a snag trying to install poly bushings around my car and thought I'd turn to the experts here for any insight. Is there a trick to removing the forward lower control arms from the spindle on the front end of these cars? The rear lower control arms came out when I looked at them cross, but it feels like there's no force on this earth capable of moving the forward ones. I've tried a brass hammer numerous times to no avail.
Thank you all in advance for any help you can give!
2011 Camaro 2SS/RS LS3
Mods: Kooks 1 7/8" LT Headers, CAI Intake w/ APEX Race Scoop, Bo White Ported Throttle Body, MGW Short Throw Shifter, Powerbond 25% Underdrive Pulley, Borla ATAK Catback, Full DSE suspension, Bilstein B6 shocks/struts, Yukon 4.11 gears, 1.25" drop
Dyno Tuned by Brian Turner of Dyno Tune Motorsports
DavoinShowerHandel is offline   Reply With Quote
Old 08-21-2023, 09:26 AM   #2
kevint
Drives: 2013 1SS
Haven't done these yet myself but heating the area of the knuckle that the control arm connects to and hitting it with a big effing hammer seems to be the way to go. You'll likely have to use something bigger than the brass hammer you're currently using. You can also try putting a jack under the threaded end of the ball joint and applying a little upward pressure in addition to heating and hammering.
kevint is offline   Reply With Quote
Old 08-21-2023, 09:46 AM   #3
DavoinShowerHandel
The jack idea had crossed my mind and is about the only thing I hadn't got around to trying yet. Heat & hammer alone didn't even make it flinch. I'm half-tempted to just buy a new spind and control arm and start from scratch if the jack doesn't want to make it work.
Old 08-21-2023, 10:21 AM   #4
kevint
Drives: 2013 1SS
If a new control arm is in the cards you might as well also get a pickle fork or some other ball joint removal tool and try that before buying a new knuckle (which might also mean a new hub and rear lower control arm).
Old 08-21-2023, 12:50 PM   #5
DavoinShowerHandel
That's my worry, and what I'd love to avoid, is having to replace the entire knuckle. I wouldn't mind so much getting a new control arm if the doggone thing would just come out one way or another. Rear arm came out with the first tap, no issues there.
Old 09-07-2023, 03:44 AM   #6
Leadsled
Leadsled's Avatar
Drives: 2010 Camaro SS 6MT
I used a 4lb brass hammer. Came out in one big swing.
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
Leadsled is offline   Reply With Quote
