Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 08-09-2018, 08:55 PM   #1
stt816
Drives: 2012 Black 2SS/RS M6
Oil Burning?
I just checked my dipstick 15 minutes after I drove my ss and I see oil only at the bottom of the dipstick. No where near the x's. I drive pretty aggressive on the street but should this be happening? There are no leaks in my driveway. Is this normal? Just got an oil change not too long ago
Pfadt Race Engineering 1.25" Lowering Springs| Pfadt Spec Performance Street Alignment|ZL1 Front Bumper Conversion|ZL1 20x9 Rims|Pirelli P Zero All Season Plus 275/40R20Y Square Setup||Footwell Lighting|G2 Gold Painted Brake Calipers
Stainless Power Long Tube Headers|Cold Air Inductions Cold Air Intake|VMAX CNC Spiral Ported Throttle Body|Stainless Works Retro Chambered Catback| Vitesse Throttle Controller
--Jannetty Racing Enterprises Dyno Tuned|408 RWHP
stt816 is offline   Reply With Quote
Old 08-09-2018, 09:17 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Check it again in the morning before you start it.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-09-2018, 09:19 PM   #3
stt816
I did that the time before this and same results
Old 08-09-2018, 09:34 PM   #4
CamaroFred
CamaroFred's Avatar
Did you check it after the change?
Some have reported they only put in 6 quarts instead of 8.
Top it up and keep an eye on it.
2011 1SS/RS LS3 CGM
Old 08-09-2018, 11:07 PM   #5
stt816
any certain amount i should be putting in it at first?
Old 08-10-2018, 07:58 AM   #6
CamaroFred
CamaroFred's Avatar
Dump in a quart and then see where it is on the stick. The 'add' mark (bottom of the Xs) is one quart.
Better to be a little low than overfilled.
If you are running synthetic it will run into the pan pretty quickly. If dino oil you should wait some time for it to drain down.
2011 1SS/RS LS3 CGM
Old 08-10-2018, 11:35 AM   #7
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Exactly.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 08-10-2018, 12:34 PM   #8
stt816
so I put in 1 quart and its coming right below the bottom of the x's..Should I put in any more?
Old 08-10-2018, 02:50 PM   #9
CamaroFred
CamaroFred's Avatar
You should add another quart. The level should always be within the X's.
Sounds like they only filled it with 6 quarts like the V6s take.
2011 1SS/RS LS3 CGM
Old 08-10-2018, 10:00 PM   #10
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I am curious who the hell changed your oil without checking the recommended oil capacity.
InFiD3ViL is offline   Reply With Quote
Old 08-11-2018, 02:58 PM   #11
stt816
I definitely got charged more because they said I have an 8 quart engine capacity...I'd be surprised if they didn't fill it to 8..they showed me the dipstick after and it was in the x..maybe just from driving hard it went down?
