dave@hennessey
Old 07-02-2016, 09:24 AM   #1
Deep12
Drives: 2015 1le
Shifting problems!!!!!
Coming home from the Camaro rally the other day and suddenly couldn't shift into 2nd,3rd,and 5th with my 2015 1le! With the motor off I could get into every gear, anyone know what's going on?
Deep12 is offline   Reply With Quote
Old 07-02-2016, 10:43 AM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Tow that baby directly to the dealer. There shouldn't be a problem, and the dealer should be the one to find and fix the problem on a 2015. We're you doing anything unusual prior to the issue starting? Any shifting issues prior to that? It's anyone's guess with the info we have whether it's an internal, linkage or shifter problem at this point.
Good luck and let us know what it turns out to be.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 07-02-2016, 11:26 AM   #3
Deep12
Drives: 2015 1le
I wasn't doing anything unusual, just cruising. I have a appointment Tuesday and will let everyone know. Thanks
Old 07-02-2016, 08:06 PM   #4
Iroc Drew
Iroc Drew's Avatar
Drives: 2015 1LE 2SS/RS CRT NPP AYZ NAV SUN
Did you get any messages on your drivers info screen when this was happening? Also do you have a Skip Shift eliminator on your car? If not the computer locks you out of 2nd and 3rd until a certain RPM is reached.
1989 IROC Z L98.
2015 Silverado LT.
2015 2SS 1LE.
Iroc Drew is offline   Reply With Quote
Old 07-09-2016, 08:58 AM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
What did you find out?
camguynj is offline   Reply With Quote
Old 07-09-2016, 09:07 AM   #6
vinman
The BBOMG fill-in husband
vinman's Avatar
Drives: 2015 2SS/RS 1LE AKA V1LE
1st to 6th shouldn't be too bad
UPSTATE C5 MEMBER
vinman is offline   Reply With Quote
Old 07-09-2016, 04:40 PM   #7
Olddudesrule
Resident nomad
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 08-08-2016, 08:14 PM   #8
fatboy99
fatboy99's Avatar
Drives: 2014 Camaro 1LE
Had this happen once on my 2014 1LE, it was as though the shift eliminator locked on. Made it to the house, unhooked battery for a couple hrs to allow any computer resets. Never has done it since, driven probably 10,000 miles. I think it was just a electrical glitch.
fatboy99 is offline   Reply With Quote
Old 08-08-2016, 10:17 PM   #9
Olddudesrule
Resident nomad
OP, any resolution? Nice to know what the outcome was for future reference.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 08-11-2016, 12:35 PM   #10
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Normally ...
The skip shift "feature" only blocks 2nd gear.
The dic display diagram shows shift 1st to 4th but the driver can still shift 1st to 3rd if he wants.
When engaged, that transmision mounted lockout solenoid just blocks second gear.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 09-02-2016, 06:53 PM   #11
Deep12
Drives: 2015 1le
Finally got it fixed, the shifting cylinoid was stuck, the replaced it and it works fine now.
Old 09-02-2016, 08:53 PM   #12
camaro_uk
Drives: 2015 1LE Camaro
Just curious, would a skip shift eliminator cured the problem as well?
camaro_uk is offline   Reply With Quote
Old 09-03-2016, 12:43 PM   #13
Olddudesrule
Resident nomad
Ok, gotta ask, what/where is the "shifting solenoid" on our manual transmissions? Master cylinder to slave cylinder to shift fork to release bearing, etc......what the heck is the shifting solenoid? If I missed that he's driving an L99, then someone just slap me now..... (edit: I see he owns a 1LE....no slap please)
Would love to understand the cause of the OP's problem.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 09-03-2016, 08:34 PM   #14
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
There are no forks on a hydraulic TO bearing. However, I didn't know there would be a solenoid on a manual trans. But these are pretty sophisticated today.
Kendall421 is offline   Reply With Quote
