Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 11-16-2021, 06:35 AM   #1
BlkCamaroVert
BlkCamaroVert's Avatar
Drives: '11 2SS/RS L99 Vert IO Interior
Is a high flow cat inviting problems?
I have an extended warranty. Will a high-flow cat void the warranty? Also, I already have a CAI and performance mufflers. Will I need a tune after that sort of mod?
BlkCamaroVert is offline   Reply With Quote
Old 11-16-2021, 08:26 AM   #2
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Yes and yes. It will affect your o2 sensors as well.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 11-16-2021, 09:39 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ exactly what he said...
1JEWLDSSRS is offline   Reply With Quote
Old 02-27-2022, 01:43 PM   #4
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
It will void your warranty. However the tune question is debatable, some say yes you need a tune and some say no.
I personally had a Roto fab CAI, 2.85 pulley , long tube headers and straight pipe, no tune and it ran great!!!
But without a tune you will get a cat inefficiency code from the 2nd O2 sensors, that won't effect performance but the light is annoying.. most people have that code tuned out.
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 03-13-2022, 05:37 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I've had Solo HF cats for about 10 years now. The Solo's come with rear O2 extenders, that get the sensors out of the stream and won't give a CEL. I also have had a tune for the past four years, mainly for the trans.
SlingShot is offline   Reply With Quote
Old 05-23-2023, 08:12 AM   #6
Hurst SS
Drives: 2010 Chevrolet Camaro SS
Stainless Works Header and Cats Install do I need a tune?
I have a 2010 Camaro SS, 6.2 Auto trans and I'm adding Stainless Works headers and cats, along with cat back stainless exhaust upgrade. I have read some about needing a tune and not needing a tune..... do I need it or not?
Hurst SS is offline   Reply With Quote
Old 05-23-2023, 08:40 AM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
To get the most out of those mods, yes you will need a tune, otherwise you will at some time or other get a CEL.
Old 05-28-2023, 07:37 AM   #8
Bartbart
Drives: 2014 Camaro SS
I melted my high flow cats
Bartbart is offline   Reply With Quote
