TireRack
Old 06-27-2013, 01:27 PM   #1
Levischilz
Drives: 2012 Camaro SS Transformers Edition
Twin Turbo Comparison
I've finally decided to go the twin turbo route on my new 2012 camaro ss its a manual 6 speed ls3. I've been debating PD vs centri vs twin's and have made the decision to go twin turbo.
I looked at granatelli and hellion and IPS and AGP.
I dont plan to run anything over 650 ish rwhp for some time. Later if money permits I will possibly forge the block but dont plan much more extreme than that as I dont want to buy a new motor or build anything for like 1k+ range. Evern if I surpass the 650 rwhp range it would be to get into the 700's nothing more since its a street toy. The only other big change I would like to make would be a cam mostly for the sound at idle.
I've narrowed it down to the IPS entry level kit and the AGP TT kit.
Could anyone give me some details of the difference between the 2. I have found a couple things. I like the tial stuff from IPS but then love the cast parts from the AGP kit. Also the agp kit has a mean intercooler which I love that it gets good air above and below the bumper support. I also think the AGP kit is ball bearing turbo's. Im somewhat familiar with turbos but its been a while. I put a turbo kit on a na eclipse years ago.
Im mostly looking for some who have knowledge in turbos give me some info on the difference between the turbo's on the 2 kits and which may be better. I also am strickly going to be using this for weekend fun its not a DD but I also dont do 1/4 or track atm. I think the kits are around 1500 price difference.
Thanks for any info I appriciate it !! Levi
Levischilz is offline   Reply With Quote
Old 06-27-2013, 02:07 PM   #2
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Here is a comparo but the AGP and IPS entry level were not out yet when this was made.
http://www.camaro5.com/forums/showthread.php?t=94520
BTW, I installed the IPS non-entry level. Great kit with nothing nut the best parts and welds.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 06-28-2013, 10:08 AM   #3
Levischilz
Anyone chime in on the thoughts of the agp turbo size vs the ips turbo size?
Old 06-28-2013, 10:28 AM   #4
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Levi,
I cant speak about the AGP kit, mainly because I have no physical knowledge of it, nor have I read any press other then the thread in this section.
I will of course speak about our "entry" kit.
Our entry kit is the same as the competition kit, less just a few details, mainly components (example non SS tial turbine housings). We are releasing the kit with some custom silicone IC adapters similar to what you may have seen in photos from AGP, I have these here but cant release photos just yet until the press kit comes out.
We use REAL garrett turbos, no knock offs, no imitations, the best, durable OEM grade turbos. Yes they are not ball bearing but we did quite a bit of dynamic analysis on the turbo sizing for the application range intended on the kit and these turbos will spool fast and create peak torque very well and hold power. BB are nice to have, but they come with a cost of course and there is a relative marginal benefit which is the consumers decision. And as a caveat to specing these turbos properly we do not have to have a overly large intercooler (comparing the AGP photos I have seen, its seems large for 6-8 psi...again though I dont know about it other then a cell phone pic). I worry the agp being that "long/tall" with the end tank design the air flow across the whole intercooler would not be that great in other words the air would have some flow/pressure differences across it and not cool the charge as "efficiently", yes it would have a fair air charge I am sure but big for the sake of big can have its issues especially at lower air speeds (boost). ( disclaimer I do not know any "real" results this is just educated speculation about their system ). Our kit produces consistent air inlet temps around ambient or with in 15 degrees of ambient even on these 80+ degree days, this is why we make good power, tuners appreciate this. We have several clients with the base intercooler in the 800 hp range, so its got some room for you to grow.
As for the components and materials of our system, we control as much as we can. All the metal is USA grade, fabricated here in house, guaranteed by IPS. The hoses lines fittings we use are all very high grade, no push lock hard ware store stuff here for the sake of compromising quality. We control all the finishing options right here in the shop, and the lead times for them, which is great.
I believe this kit is just flat out the best money you can spend to make the 600 (auto) to 645 (6speed) on a bone stock engine. You would be hard pressed to spend less to make more with all the benefits of drivablity and ease of the system. I know this isn't comparing kits, but just a general pitch lol. Oh and there is room to go higher HP with the entry turbos, this is not all they will make
Just let me know if there are more specifics, I am back "trolling" this forum more regularly and will answer all questions / concerns.
IPS Brandon is offline   Reply With Quote
Old 06-28-2013, 12:53 PM   #5
Unreal
Drives: 2006 Z06
I just goto lunch at AGP every day and bug them, so I don't know 100% of the details.
Like Brandon said, can't speak about the IPS kit because I haven't seen it. I've driven then AGP car many times. IATs are almost ambient, and no overheating even in Phoenix. It should be 120 today and the shop car runs fine with cold a/c. All parts are ceramic coated to help keep heat controlled.
AGP uses the same suppliers for a lot of parts as GM/Ford/Chrystler. The casting house cast OEM manifolds for most of the big 3. They have sold thousands of turbos kits and have millions of miles on the kits with OEM reliability and quality. That was the primary focus of the kit, was a OEM level kit that the average person can put on in an afternoon and make big power.
Comparing turbos sizes is hard. AGP has about 100 combinations of turbos that can fit. I don't even know what turbos IPS uses but it looks like 57 trim stage 3 garrets on the budget kit, which are a decent turbo. I personally like the Borg Warners that AGP uses as the base turbos a bit more. Garret and Borg Warner are both top level OEM suppliers with great turbos. Can't go wrong with either.
If anyone from C5 ever responds to them becoming a vendor I can have the owners/employees actually provide real data, info, pricing, etc but they can't get anyone to take their money to become a vendor.
You won't be disappointed with either. I've dealt with IPS on a few things and I've always been happy. I've known the owners of AGP for 15+ years and we go way back. I know they take care of customers, have awesome warranty (rarely used), and designed a top notch kit.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 06-28-2013, 01:22 PM   #6
Levischilz
do you have any more info on the turbo's agp kit uses? journal/bb? etc
Im just speaking for base kit on both im sure there are upgrade options everywhere. Start playing with that stuff and the price jumps rather quickly! lol
Old 06-28-2013, 01:41 PM   #7
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
AGP Turbos... Journal. Borg Warner base turbos with AGP upgrades below.
So the 'little' 1000hp base turbos are-
56x80mm compressor wheel
3" inlet compressor housing
61mm turbine
These should be capable of 1000whp in a M/T car.
S256 upgrade-
56x84mm comp wheel
4" inlet port shrouded comp hsg.
65mm turbine
These should be capable of 1100+whp in a M/T car
S261 upgrade-
61x88mm comp wheel
65mm turbine
These should be capable of ~1400whp in a M/T car
**Turbos in red are physically bigger that require you to notch a little to make fit.
Turbine housing a/r ratio options will usually want to pick between the .63 or .82
The .63's are good for stock displacement running up to about 6500rpm on a smaller or mid size cam. These give fast spool and will support a lot of power.
The .82's are recommend for any car with a stroker motor or spinning extra high RPM.
And we have a 1.0 and a 1.25 that will also fit but will likely not be needed.
All these housings are a very high flow design, not to be confused with other .63's and .82's T3's.
Matt @ FSP is offline   Reply With Quote
Old 06-28-2013, 01:42 PM   #8
TH SS Vert
TH SS Vert's Avatar
Drives: 2013 Camaro SS
Originally Posted by IPS Brandon View Post
Levi,
Brandon--since I have your entry level kit with the 6-speed, how far do you think these turbos could be pushed on the stock cubic inches? 800 rwhp? I'm sure you know that I'm at between 9-10 lbs of boost. I wonder how far they can be pushed before they're out of their efficiency range. By the way, the car is awesome! Thanks!
Mark
2013 Camaro 2SS coupe/6-sp manual/Inferno Orange Metallic/NPP exhaust.
IPS entry level twin turbo kit
681 rwhp/665 rwtq
10 lbs of boost
TH SS Vert is offline   Reply With Quote
Old 06-28-2013, 01:48 PM   #9
Levischilz
Would the investment be worth it on either kit to move to a ball bearing turbo? I know there better but it does add considerable cost from what I can find. idk why I thought the agp's were bb. Hrm tough to decide between the 2!! Seems if there so similar why the agp have such a higher cap on its ability to make power (up to 1k) vs the entry lvl ips kit.
No more smoke vert?
Old 06-28-2013, 02:29 PM   #10
killmode_on
Drives: 2011 2SS/RS
No more smoke vert?
I don't think BB would be worth the upgrade cost.
The AGP kit uses larger higher flowing turbos, larger piping and intercooler. That would be where the extra hp comes from.
Be vewy vewy quiet, I'm hunting GT500's.
killmode_on is offline   Reply With Quote
Old 06-28-2013, 02:56 PM   #11
Levischilz
Hrm.. Sounds good guess I'll try and hold out for a ago dyno sheet would be nice to compare the slope on the graph of the 2 to compare there hp/tq to rpm
Old 06-28-2013, 03:34 PM   #12
camarostar2010
Drives: 2011 SS
Well I have the ips med level kit for over a year now. The power is very strong, in so much I have blown a stock rear with ease. No burns out, and no slicks. The idle is great, the sound is great, torque from 2k -to 6200 is flat. Car never heats up to much. IAT are about 110 in a 90 deg day. I will be boostin 15-20 pounds soon. I run 10 psi for the street without a hiccup. My only complaint is that I feel the turbo, and external pipes sit too low for NY and NY "EFFED" up streets. I must mention I have the billet and ceramic bb options. I am sure both these kits are great. But U can vouch that the ips kit is excellent. The power, reliability, and parts are excellent for the price. PS the ips kit aint cheap, but neither is racing. You wanna play u gotta pay, simple fact
camarostar2010 is offline   Reply With Quote
Old 06-28-2013, 05:10 PM   #13
TH SS Vert
TH SS Vert's Avatar
No more smoke vert?
Nope! All is good!
681 rwhp/665 rwtq
10 lbs of boost
Old 07-24-2013, 11:20 AM   #14
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Pushing this back to the top. Looking to keep the dialogue going. I do NOT want to make this a pissing contest between the IPS and AGP fan boys. Obviously any info that comes directly from AGP or IPS is going to paint their respective system in a favorable light. I’m sure I’m asking too much, but if it were possible for an experienced, qualified, neutral third party to get their hands on both kits and speak to their strengths and weaknesses, that would be idea. Turbos vs. turbos, inter-cooler vs. inter-cooler, piping vs. piping, ease of install, clearances, etc. Seems like you can’t go wrong with either kit, but the more information that is out there, I think the more kits both companies will sell.
Unavowed is offline   Reply With Quote
