09-27-2016, 08:25 PM | #29 | |
Make America Fast Again
Drives: 2016 HBM 1SS - M6 Join Date: Sep 2016
I thought it was odd because my 4th gen would break it loose no problem at all. Then again that's a straight axle car which I'm sure makes a difference |
09-27-2016, 09:41 PM | #30 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
No changes with mine. Runs just as fast at the track as it did when I had 500 miles on the OD.
09-27-2016, 11:09 PM | #31 |
Drives: 2018 2SS 6MT Hot Wheels Edition Join Date: Jul 2016
I'm sure most of you don't care about the 2.0 T but I was able to chirp my tires in the first three gears while taking my brother for a test drive. I have the M6 with 3.37 gear ratio.
09-28-2016, 06:27 AM | #32 |
Drives: truck Join Date: Aug 2015
09-28-2016, 07:32 AM | #33 |
Drives: 2016 1LT V6 6MT Convertible Join Date: Aug 2016
A8 V6= Open differential (spin tires due to lack of traction)
6MT V6 = Limited Slip differential (significantly reduced tire spin compared to the A8 V6) SS V8 MT6 + A8= Limited Slip Differential (LT1 engine easily overpowers the rear tires!) Much like the honey badger, the LT1 engine doesn't give a F^@k! But...The V6 6MT cars with limited slip differential can't brake traction as well as the LT1 SS. However, the A8 V6 cars brake traction all day because there is no LSD. This means that the A8 cars cannot put power down as well as the M6 cars (theoretically). Another way of saying this is that the A8 cars will allow the V6 to overwhelm the tires, even if it means reduced forward propulsion. On the track, this means that the A8 V6 might spin out where the 6MT might gently rotate. What this translate to iA8 V6 guys braking traction, while the 6MT guys wonder why they can't. Things get confusing when the SS guys chime in saying that their 6MT brakes traction willingly. Well, I would hope the v8 LT1 could brake traction with it's 450HP and 450 Lbs/Ft of Torque! All V8 cars have limited slip rear differentials, but the V8 is strong enough to overcome the effects of the differential, so you always get tire spin when mashing the throttle. |
09-28-2016, 08:07 AM | #34 | |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
Leave the line at 3000rpm though and all you get is spining tires with the M6 |
09-28-2016, 12:06 PM | #35 | |
Drives: 2017 2SS Convertible Join Date: Feb 2016
This all works out just fine in real world driving... If I'm driving a manual, crawling along at 10 MPH, and I really want to GO, I'll push in the clutch, get the RPMs up, and I'll be gone. I rarely encounter this scenario though. More likely, if I'm crawling at 10 MPH in first gear, I'll just ease into the gas so as not to bog the engine. In an auto, just mash the go pedal if you want to GO.
Nightfall Gray Metallic / Adrenaline Red / 6MT / NPP / MRC / 56V wheels 1100 - 07/15/16 3000 - 08/18/16 | TPW 09/05 - 08/23/16 3100 - 08/30/16 | TPW 09/12 - 08/30/16 3400 - 09/06/16 | TPW 09/05 - 09/06/16 3800 - 09/15/16 | 4200 - 09/20/16 6000 - 09/29/16 - on Camaro's 50th Birthday! |
09-28-2016, 07:59 PM | #36 |
Red Hot A8
Drives: 2018 ZL1 1LE, black Join Date: Sep 2016
I tried this today. Weather was sunny and hot, about 92. A8, took off and wheels broke loose with no problem. Also did a rolling one at about 20 mph and got a good chirp out of them
09-28-2016, 08:04 PM | #37 |
Drives: 17' Camaro 2SS 16' Jeep GC SRT Join Date: Aug 2016
I can get this thing to hook up quite well. I'm actually quite excited thinking about the better tires that are on their way to me. I did have it a little sideways today.
09-29-2016, 04:14 AM | #38 |
Drives: '17 2SS H50 Join Date: Mar 2016
I was thinking about this thread yesterday while the wife and I were taking a short cruze. On our way home I stopped for gas, somehow the car ended up in sport/competitive mode on the way out of the pumps. Long story short, my H50 will break the tires loose in 1st and 2nd rather abruptly with the wife saying, and I quote "you'll go to jail doing that". Hahaha
Heath
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
09-29-2016, 09:11 AM | #39 |
Drives: Black 1SS NPP Join Date: Apr 2016
I do not lose traction much either, but if I were you I would try this in track mode and stomp on the pedal. the throttle in track vs tour or sport is a lot more jumpy and should help you lose traction a bit easier. I also have a m6 and it seems everyone with an a8 has no problem
09-29-2016, 03:09 PM | #40 |
Drives: 2016 camaro 1SS Join Date: Jun 2015
I'm getting ready to leave for a trip and taking the SS. So putting some miles on this weekend:-)
09-29-2016, 04:05 PM | #41 | |
OP - depending on weather and road conditions (colder weather or tires, low traction asphalt) I can get the tires to break loose by punching the throttle with the clutch all the way out while in first gear (M6). Most of the time the car just squats and goes. Pretty normal - I think. In general these tires hook well and the chassis/suspension plants the tires to the road. Because after all spinnin' ain't winnin".
09-29-2016, 04:48 PM | #42 |
Where you located in KY?
