Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 10-05-2013, 05:46 PM   #1
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
delete
delete
Vicster is offline   Reply With Quote
Old 10-05-2013, 09:58 PM   #2
sporto20
sporto20's Avatar
Drives: 1. 2010 2SS (sold) 2. 2013 ZL1 M6
I have the LPE GT9 cam and love it!!
710 RWHP; 667 torque
Ported Supercharger, Snout and TB
Rotofab CAI
Kooks 1 7/8” Headers w/ high flow Cats
LPE GT9 Cam,
BTR Springs and Comp Pushrods
160 degree thermostat
2.55" Upper/9.1" Lower SC pulley w/ balancer
LPE solid isolator, ID850 Injectors
LPE heat exchanger w/ fans
Centerforce Dual Friction Clutch
Custom Tune
sporto20 is offline   Reply With Quote
Old 10-06-2013, 08:46 AM   #3
Flavorwrench
Flavorwrench's Avatar
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo
This is Rocket Science!
The good news is that all of this has been done many times over and I think you will agree if you do additional research over on CTSVOwners .com. Look up "Rubber Duck" if you want the rocket science explanation, nothing short of amazing.
The 1 7/8 headers and 90mm TB will will put you in a different parts list. My advice would be to save your money on excessive
heads/blower porting, unless you are doing it yourself. Porting the snout is a must! Check out Brian Tooley's camshafts, or Keith's Street/Track sweeper series (If you can still get one) Everyone has an opinion for sure but for me I'm glad I didn't get caught up in the bigger the better with camshafts, the BTR2 is making over 700 to the ground. Spend your money on upgrading your HX and HX pump and add capacity with a coolant tank. Running 15lbs of boost generates a ton of heat and the PCM will cap your efforts by pulling timing. 92 octane up here in WA, was huge deciding factor for me. Hope some of my "Opinions" help you with your build, Good Luck!
2012 CAMARO ZL1
Brian Tooley Racing Stage 2 Camshaft, BTR Platinum Springs, Titanium Retainers, Comp Cams pushrods, ID850 injectors, NGK TR7ix Plugs, My Ported Blower Snout (102mm), My Ported Blower, Nick Williams 102mm TB, Airaid CAI, LPE 2.55" upper, 50mm & 100mm pulley's, Gates Green, Meziere HX Pump, KD Innovations HX, My HX Tank, Saikou Michi Cans, 160º Thermostat, IW Balancer, 9.55 blower pulley, Stainless Works 2" headers w/high flow CATS, Kenne Bell BAP, NGK AFX NTK 722.12 rwh / 675.46 rwt 92 Octane
Flavorwrench is offline   Reply With Quote
Old 10-06-2013, 11:20 PM   #4
hognutz
hognutz's Avatar
Drives: 2013 ZL1
don't forget about the ZR1 cam. 35hp oem drivability. $109
if you going to pull the snout port it.
porting will definatly make more power but you just have to decide how far you want to tear down and how much money you want to spend.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 10-07-2013, 08:41 AM   #5
ZL1RHINO
Drives: 2013 black on black
Just porting the snout doesn't do much. I would port the blower as well.
ZL1RHINO is offline   Reply With Quote
Old 10-07-2013, 09:16 AM   #6
Flavorwrench
2012 CAMARO ZL1
Old 10-07-2013, 10:06 AM   #7
red67
red67's Avatar
Drives: 2013 ZL1 M6
call Late Model and be done
red67 is offline   Reply With Quote
Old 10-07-2013, 10:23 AM   #8
sporto20
sporto20's Avatar
The drivability around town is excellent!! The exhaust flaps keep it from being too loud when cruising, but is is a BEAST in start-up and WOT.
Rotofab CAI
LPE GT9 Cam,
Custom Tune
Old 10-07-2013, 03:20 PM   #9
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
Here is the deal I spoke to lingenfelter just a couple of days ago. if you look at my list of parts you will see what i have..i was going to port the snout and add the TB together..But lingenfelter told me that its not worth the 30hp everyone thinks it is. they told me not to bother to port it. they said the only time they port it is when they are doing a cam,otherwise the cost of pulling it and porting it is not worth it...
But since your already doing a cam then go ahead and do it,lingenfelter told me the reason they port it is the smooth out the thottle response not for the power gain.. if anyone should know its them.. I was told that they do at least 100 ZL1's a yr in house ,not including all the parts they sell.
I have the GT9 cam which does not have a lot of lobe for a larger cam ,but it does pull like a huge train on the freeway ,it has a huge KICK IN THE PANTS FEEL,LOL i hope it helps
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 10-07-2013, 03:39 PM   #10
Vicster
Vicster's Avatar
Drives: 13' ZL1
1,000hp IS NEVER ENOUGH!!!
Old 10-07-2013, 04:07 PM   #11
dmax86
dmax86's Avatar
Drives: 2016 Z06 C7R
BTR Stage 3
2013 ZL1 BONE STOCK! LOL
dmax86 is offline   Reply With Quote
Old 10-07-2013, 05:49 PM   #12
fourcammer
Drives: 7331
eps is making mine .
fourcammer is offline   Reply With Quote
Old 10-07-2013, 07:59 PM   #13
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Do you have an auto or a manual? It makes a difference when you get to the camshaft. It you have the option of revving it up and dragging the clutch a little at start you can handle a lot more cam. With my car you have to work the clutch a little more than the stock engine or it will die on you. I don't think you can put the really radical cams in an auto without stall problems, unless you keep the idle very high, and then you start battling the torque converter...
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 10-13-2013, 05:33 PM   #14
fourcammer
Drives: 7331
Originally Posted by Vicster View Post
So what is the specs of the cam?
I knew someone would ask this lol. I will call Geoff back and get exact numbers .
