08-11-2022, 09:04 PM | #29 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Looks nice,Are they going to take it back?
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
08-12-2022, 07:32 AM | #30 |
I emailed them yesterday and haven’t heard back just yet.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
08-12-2022, 09:33 AM | #31 |
Drives: 2013 ZL1 Join Date: Sep 2021
Can you have a set of 12mm/14mm sleeves made?
08-15-2022, 03:35 PM | #32 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
08-15-2022, 09:49 PM | #33 |
The more I read the more I keeping hearing good about PST.
08-16-2022, 05:24 AM | #34 |
After thinking through it and making sure the driveshaft fit correctly, I remembered that the DS is centered on pinions from the trans and diff. I decided to drill the holes out on the diff end of the DS to fit 14mm bolts. So me and a buddy created a jig on the drill press to hold the DS and used a pilot bit, then a 9/16 bit to drill the holes out. Went slow and easy and turned out well. Sorry, no pics taken...
Now i'm just waiting for shorter bolts for the DS to diff to arrive which is looking like today, most likely tomorrow. Its a pretty snug fit especially with the offset diff bushings, but to my amazement the metal shield protecting the gas tank still clears the DS. I was expecting to have to cut/trim it some.
08-16-2022, 08:38 AM | #35 | |
08-18-2022, 12:56 PM | #36 | |
I finished it up last night and took it for a drive just a little while ago. Its very smooth and nothing unusual that I could feel. Pleased thus far.
08-18-2022, 03:21 PM | #37 |
I spoke with PST and Guof coast today and both were very pleasant, Gulf coast really took their time and went over everything and I honestly and leaning towards them. Both do offer Carbon Fiber options but just are not on their sites at the moment.
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. Last edited by Joe.G; 08-19-2022 at 09:03 AM. |
08-19-2022, 05:54 AM | #38 |
What other options do they offer?
08-19-2022, 09:03 AM | #39 |
I was typing on my phone, it was supposed to say Carbon Fiber.
08-19-2022, 04:39 PM | #40 |
Haha.. been there..
08-21-2022, 08:41 AM | #41 |
Ashen, have you had a chance to take the car out again and run it though different speeds? How are you liking the drive shaft? Notice a difference?
08-21-2022, 04:52 PM | #42 |
Yes, been on the highway several times now and all good. I cant tell if there is any more noise than before though, doesn’t sound like it to me. Certainly feels more solid and responsive. Happy with it.
