dave@hennessey
Old 05-18-2013, 09:40 PM   #1
1sick7
Drives: 2012 camaro convertible ss
whats your input on a thicker head gasket ?
whats your opinion on thicker head gaskets to lower compression on a boost engine ?
1sick7 is offline   Reply With Quote
Old 05-18-2013, 09:42 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
How much more and we would need more info than that bud. I need DETAILS sir.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 05-18-2013, 09:57 PM   #3
1sick7
I HAVE A LS3 . JUST UPDATED MY BLOCK TO LUNATI RODS , FORGED PISTONS , BUT NO DISHED PISTONS , MY PISTONS STUCK UP A LIL OVER THE DECK , MACHINE SHOP TOLD ME TO RUN A .53 GASKET , I HAVE THE TURBONETICS KIT AND WAS WONDERING IF I RUN LIKE A .100 GASKET IF THAT WILL HELP LOWER MY COMPRESSION AND BE SAFE ?
THANSK FOR YOUR TIME
Old 05-18-2013, 10:15 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
How much do they stick out of the hole?
Did they say .53 compressed?
Old 05-18-2013, 10:19 PM   #5
1sick7
YES HE SAID IL BE FINE WITH A .53 COMPRESSED GASKET , WHATS YOUR INPUT ON PUTTING A MORE THICKER GASKET TO LOWER MY COMPRESSION A BIT ??
Old 05-18-2013, 10:22 PM   #6
blake-b
blake-b's Avatar
Drives: 2009 ZR1
LSx pistons can ride out of the hole up to .007 I think. Mine are .004 out of the hole using LS9 gaskets (.051 compressed).
You need to know how far out of the hole yours are. What pistons do you have as far as part number goes?
Old 05-18-2013, 10:24 PM   #7
1sick7
I TOUGHT LS9 GASKETS WHERE .055
Old 05-18-2013, 10:25 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Everything I have read says .051.
Old 05-18-2013, 10:29 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Compressed GM MLS gasketz they are like ~.048 iirc
How are you determining compression? What are you coming up
Old 05-18-2013, 10:30 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The LS9 gaskets have 7 layers vs. 5 layers so the .003 probably comes from that.
Old 05-18-2013, 10:46 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yes more layers but same thickness as Ls3
Old 05-18-2013, 11:47 PM   #12
1sick7
What would you guys think of going with like a 0.100- .125 ?
Old 05-19-2013, 12:53 AM   #13
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
Going from a stock head gasket to a .100 head gasket would lower your compression about 1.2 points (say 10.7 to 9.5).
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 05-19-2013, 01:43 AM   #14
1sick7
Is there Any cons to that ?
