06-30-2022, 09:24 PM | #1 |
Drives: 2018 Camaro 2SS Join Date: Jan 2021
Ground Effects Kit + Lowering kit & sway bar upgrade
Hi Camaro6,
Currently running a 2018 2SS without magride suspension. Considering adding the lowering kit (86773565) and sway bar upgrade (84401188). The car is my daily driver, and I go to the track about once a month during the summer. Buhhhht.... I'm also seriously considering the GM Ground Effects Kit (84116167) in black. And I know it's been asked before, and it seems the Ground Effects don't really reduce ride clearance (from photos I've seen, unsure in person). I'm wondering. Does anyone have all of the above on their vehicle? And do you track it without scraping? Or if you have all 3 of the above, is it obviously too low? Thanks for any insight, |
07-01-2022, 05:56 AM | #2 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
I would think that would not be much different than a 1LE, has ground effects, is lower, I can't imagine you would have any issue, other than the obvious occasional driveway apron lol
07-01-2022, 07:29 AM | #3 |
The front splitter does reduce clearance by about an inch. May or may not be a problem, depending on where you drive, because the standard 2SS has a fairly large clearance out of the gate. To prevent scraping on badly built driveways and parking lots, I added a couple pieces of this to my (OEM) splitter, it works pretty well: https://www.amazon.com/stores/SLIPLO...3-33FA8BF186B3
07-01-2022, 09:44 AM | #4 | ||
Is 1LE actually lower? Appreciate the recommendation on scrape protectors ha |
07-01-2022, 10:29 AM | #5 |
youll be fine i have factory 1le front splitter and i was lowered on springs for awhile about 1" drop now im on coilovers so probably about 1.5" drop no issues
07-01-2022, 02:02 PM | #6 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
07-01-2022, 03:50 PM | #7 |
Yeah, I didn't even use up the one kit I purchased. I only applied a few strips to the lowest hanging 3 sections of the splitter (middle and around the first "upturn" on both sides), because covering the entire bottom felt overkill.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 07-01-2022 at 09:30 PM. |
Tags |
ground effects, suspension, track, track day |
