Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 12-12-2014, 05:22 PM   #1
PR325xi
Drives: 2013 2LT RS
My screen wont turn on
Ok, so I just turned my car on and my screen is all black, but the radio works.
https://vimeo.com/114395744
PR325xi is offline   Reply With Quote
Old 12-12-2014, 05:39 PM   #2
PR325xi
Drives: 2013 2LT RS
Touchscreen still works!
Old 12-12-2014, 05:42 PM   #3
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
What's alt ctrl del for a camaro. Hold gas and clutch then tap brakes twice.
Maybe a battery disconnect? It appears as though the video cable came loose or something.
Glad I don't have mylink. Just one more thing to break.
Very strange, hope you figure it out. I would just take it in for that and let them fix it. If you start messing around with it you could void your warranty on it.
45thAnniversary2SS is offline   Reply With Quote
Old 12-12-2014, 05:54 PM   #4
PR325xi
Drives: 2013 2LT RS
thanks
Old 12-12-2014, 05:57 PM   #5
Gee
Silver Ice
Gee's Avatar
Drives: 2011 1LT Coupe SIM
Unplug negative on your battery in trunk for 10 mins or so. If it doesnt come on, probably a loose connection.
Gee is offline   Reply With Quote
Old 12-12-2014, 07:01 PM   #6
PR325xi
Drives: 2013 2LT RS
Yes! This did it, thanks
Old 12-12-2014, 07:12 PM   #7
Gee
Silver Ice
Gee's Avatar
No problem man, I'm really glad it helped! Expensive items like that are scary and stressful.
I work with electronics. For the most part, here are the golden rules with any electronic(s):
Restart it.
Pull battery for 10 minutes
Pull battery for an hour if the 10 mins didnt work.
Hit it really hard with your fists or against something as hard or harder than your fists.
Old 12-12-2014, 07:31 PM   #8
PR325xi
Drives: 2013 2LT RS
I work with electronics too lol I just didn't want to pull the battery because it's a pain (too much junk in the trunk) lol
Now windows won't roll up automatically tho
Old 12-12-2014, 07:51 PM   #9
Gee
Silver Ice
Gee's Avatar
Ah I hate that.
You have to re index them right after you start up the car after doing the battery reset, By rolling down driver window all the way down then up.
Either do the battery reset again and re index on the first start, or follow these steps to manually reset window memory.
1-A. Open the car door which needs to have the window adjusted. Turn the ignition to the run mode. Do one door at a time !!!
1-B. In the door jam, release the harness from the door (with a medium screwdriver, pull up the release tab, pull off w/ the palm of your hand, and pull the harness off the door for a minimum of 60 seconds (this is very important as the memory will be lost).
1-C. Reconnect the door harness and lock the tab back down. Close your car door.
1-D. The DIC will ask you to lower your door glass.
Steps taken from http://www.camaro5.com/forums/showthread.php?t=70683 OP: TAG UR IT
Old 12-12-2014, 07:52 PM   #10
PR325xi
Drives: 2013 2LT RS
I did it when the dic told me but it didn't work haha it sucks
Old 12-12-2014, 07:54 PM   #11
Gee
Silver Ice
Gee's Avatar
Damn. The car knows you work with electronics. You are being tested my friend lol. Try the battery pull first its easiest. Then the manual method after. Or maybe the gremlins will be gone tomorrow morning lol.
Old 12-12-2014, 07:56 PM   #12
PR325xi
Drives: 2013 2LT RS
Damn it... All the junk is back in the trunk lol
Old 12-12-2014, 11:43 PM   #13
Blueraycamaro
Drives: 2013 2LT RS camaro
I have the same problem 2013 2LT camaro RS
Blueraycamaro is offline   Reply With Quote
Old 12-13-2014, 12:20 AM   #14
PR325xi
Drives: 2013 2LT RS
Has this happened more than once to your car? It's the first time for me.
