11-12-2014, 02:13 PM | #1 |
Drives: El camino Join Date: Nov 2014
2016 Camaro weight speculation
Well.. Sort of.
ATS-V weight has been publicised at 3600lbs. Check the link http://jalopnik.com/the-2015-cadilla...and-1657355253 If the ATS-V is a twin turbo V6 with all possible luxuries, what will a stripper LT1 camaro weigh? This is my first post here. I've been following the camaro since camaro5.com more or less. I registered because i could not believe why no one had brought this fairly new info up yet? Please, discuss |
11-12-2014, 02:34 PM | #2 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
Not sure about that link as I can't get it to work, but it could be the same as this
http://wot.motortrend.com/1411_leake...d_in_full.html we get a "daily" automotive news here at work since we are automotove supplier to Camaro/GM and this is one came through today. |
11-12-2014, 02:37 PM | #3 |
Drives: 2008 Malibu V6 Join Date: Mar 2008
Although the weight of the ATS-V is interesting, I don't think that we can draw any definitive conclusions about the weight of the new Camaro.
11-12-2014, 03:14 PM | #4 |
The link is working here!
No, we cant draw any conclusions. But this the ATS-V is the same platform. It's a fully loaded twin turbo v6 most likely used as a test ground of some sort for the camaro. If a fully loaded ATS-V weighs 3600lbs, and a base model weighing in at 3350, dont you find it likely that the new camaro will weigh no more than 3600lbs in v8 trim? If not please enlighten me. |
11-12-2014, 03:43 PM | #5 |
Drives: 2017 1SS 1LE Join Date: Sep 2014
3600 lbs sounds like a decent estimate. I personally think the v8 camaro will come in a bit heavier, I'm guessing a tad under 3700 lbs.
And on a side note, the ATS V is shaping up to be a mighty fine car, and the GT3 spec race car is looking pretty nasty. http://www.racer.com/pwc/item/108174...677703821217_n
11-12-2014, 04:09 PM | #6 |
Track > 1/4 Mile
I agree that it will likely be around 3,700 lbs. I'm sure they will put beefier drivetrain in it. However it does make you wonder about the net weight difference between the engines. The LS series of engine is light for what it is and I believe the LT1 weigh's like 30lbs more than the LS3. With the LF3 being DOHC and has turbo + plumbing I'm willing to wager it is close to being a wash.
If the 6th gen. SS comes out weighing <3700 lbs I will be delightfully surprised.
11-12-2014, 04:29 PM | #7 |
DOHC, turbo, piping, intercooler and what not.. A LT1 camaro sporting the same horespower as the ATS-V, should be lighter. Im thinking the caddy also is heavier due to is being more luxurious.
If they dont succeed in making it lighter than the already relatively light ATS-V, i'll consider it as a fail. Also.. If they cant get it lighter with a v8, how do they plan on handling the ecoboost 2.3l mustang with a 2.0liter down on horsepower? |
11-12-2014, 04:45 PM | #8 |
Drives: Really Slow Join Date: Apr 2010
wow, what a let down of a thread. more speculation. *sigh*
11-12-2014, 05:01 PM | #9 |
199
Drives: like a granny Join Date: Apr 2013
not even sort of....
title is bogus. good ol' bait n switch
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon |
11-12-2014, 05:29 PM | #10 |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
Seriously, the title needs to be changed. It's still pure speculation.
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
11-12-2014, 06:26 PM | #11 |
Drives: 2013 F-150 Join Date: Aug 2014
Agree with this^
11-12-2014, 08:28 PM | #12 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
The CTS V-Sport is also off of the Alpha platform and also has the 3.6L TT engine and weights in around 4,000 pounds.
What we don't know is how much high dollar low mass hardware was involved to get a 3,600 pound ATS-V. Might be some CF in the hood for example that you won't see in a Camaro or at least at mid level SS Camaro. Gives an idea of what might be but what will be is anyone's guess.
11-12-2014, 08:38 PM | #13 |
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV Join Date: Feb 2013
If the 2.0L ATS coupe is weighing in around 3450 lbs and the V6 at 3560 lbs,
I don't see how a V8 Camaro on the same platform is going to lose much weight from where the 5th gen is now. The V8 engine, the transmission, rear end, brakes, cooling all adds weight.
11-12-2014, 10:08 PM | #14 | |
Moderator.ca
You might have to define 'much weight' here. Because to me, that implies less than about 50 lbs and I don't see that happening. The V6 ATS is about 200 lbs lighter than the current V6 Camaro. I can't see the 6th gen Camaro adding back 150 lbs
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
