02-21-2017, 10:32 AM | #1 |
6th Gen ZL1 Front License Plate Bracket (NO HOLES TO DRILL) @ Phastek Performance
NOW AVAILABLE!!
FREE SHIPPING @ Phastek Performance DONT DRILL HOLES IN YOU BUMPER!! The STO N SHO aftermarket detachable front license plate bracket mounting system is manufactured in the USA using quality materials and parts. The front and base plates are precision laser cut and hand burnished. Each tube and rod is machine cut and hand cleaned. Each STO N SHO aftermarket detachable front license plate bracket mounting system is expertly hand welded and drilled. After it’s assembled the base plate welds are ground smooth. The bracket then receives a coat of high quality automotive trim black paint. The final step in the process is to install the pull pin and test the product. While the bracket may look simple in appearance, a lot of time and work goes into making each STO N SHO aftermarket detachable front license plate bracket mounting system to ensure you receive a quality product. Features:
ZL1 Front License Plate Bracket - #SNS101 Installation video: Last edited by Ricardo@Phastek; 02-28-2017 at 03:31 PM. |
02-28-2017, 03:30 PM | #2 |
Installation video is live!!
02-28-2017, 05:58 PM | #3 |
Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
Will this fit the 1ss 1LE? I bought the original STO n SHOW bracket for 6th gen 1SS and because of the 1LE front splitter it will not fit properly
03-01-2017, 03:08 PM | #4 | |
I have not been able to get my hands on a 1LE to see exactly with kit would fit though. Hopefully soon I will confirm. |
03-01-2017, 04:05 PM | #5 |
This is the best one I've seen yet.
Good job Recardo.. I think my wife could install it after watching you. |
03-03-2017, 04:39 PM | #6 |
Tags |
license plate bracket, license plate holder, phastek, sns101, sto n sho |
