02-21-2017, 10:18 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: Feb 2017
cylinder shut down
Was talking to a mechanic about the LS1 engine shutting down cylinders. He mentioned that I should have this disabled due to the engine needing the gas to help lubricate the top part of the stroke for the pistons. He said that he's seen V8 engines use large amounts of oil that have been run with 4 cylinders shut down. Anyone else heard of this?
02-21-2017, 10:49 AM | #2 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Not sure about LS1 engines. But your LT1 that's in a V8 camaro is direct injected, so the gas is never in liquid form to "lubricate" anything.
So... maybe wrong forum for LS1 questions? edit: Not to say I know nothing about Ls1 engines, i had one in my 4th gen 2001 z28. Far as I know, it didn't have cylinder deactivation. |
02-21-2017, 10:51 AM | #3 |
Gasoline is not a very good lubricant. Unburned fuel serves more of a cooling function in the combustion chamber.
With no spark there is no pressure or blow-by gases to knock oil (a good lubricant) off the rings. I would think lubrication would be improved in the absence of combustion. There are drawbacks to cylinder deactivation, but I would not agree with your mechanic's specific opinion. |
02-21-2017, 10:52 AM | #4 |
Drives: 2017 2SS Join Date: Jun 2014
Yeah, no LS1 engines had cylinder deactivation.
I have a 2008 G8 GT. It came with a 6L LS-based motor. Basically, an LS2 (but with LS3 heads). However, because it had DOD (Displacement on Demand), it was called an L98. |
02-21-2017, 11:21 AM | #5 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
How old is he? They stopped using leaded gas in the early 70's I think.
02-21-2017, 11:29 AM | #6 |
Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
Find another mechanic, quickly.
02-21-2017, 11:56 AM | #7 | |
Drives: 2018 Camaro 2SS 1LE, 1985 MCSS Join Date: Dec 2014
I sold the car shortly after. The AFM that was on the L99 motor (2010 - 2015) Camaro SS automatic had this issue fixed. LS3, LS1, LS2, LS9, and LS7 did not have this feature. That is why there were two different motors for 2010 - 2015 Camaro SS models L99 (A6) and LS3 (M6). The 2016+ Camaro uses the LT1 (Direct injected) motor. Although the same principal is working with AFM they have changed somethings to make it work better. I have not seen anyone talking about AFM during or loosing oil (Some people may argue catch can but that is a totally different issue ). You can remove AFM with a tune... But I would find a different mechanic or someone that is updated on motors...
2018 Camaro 2SS 1LE, White, M6, MRC, NPP, ELSD
Past/Current: 2011 Camaro 2SS Convertible, M6, Silver Ice Metallic, Inferno Orange Interior and Stripes - SOLD 2007 Monte Carlo SS, LS4, Summit White, Silver Rally Stripes - SOLD 2006 Impala SS, LS4, Black on Black - SOLD 1985 Monte Carlo SS |
02-21-2017, 12:12 PM | #8 |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
or, you could just use a Range device ( http://www.rangetechnology.com/pages/v8 )
no voided warranty like with a tune.
02-21-2017, 12:22 PM | #9 |
Drives: 2023 2SS Convertible Join Date: May 2009
02-21-2017, 01:14 PM | #10 | |
I forgot about the OB2 Plug N Play disabler... Nice Catch!
02-21-2017, 02:09 PM | #11 |
Drives: 16 Hyper Blue RS V6 A8, 09 Civic EX Join Date: Jun 2016
02-21-2017, 02:13 PM | #12 |
Red Hot
Drives: 2017 Camaro RS Join Date: Nov 2016
02-21-2017, 03:45 PM | #13 | |
I used to be Dragoneye...
Firstly, gas isn't a great lubricant in any condition. Secondly, the Direct Injection system sprays fuel well after the piston has begun to travel up to TDC...so it wouldn't help "lubricate" anything. Also, while the AFM system shuts down the spark and fuel, the valves remain closed to capture a pocket of air, and use the benefit of an air "spring" to reduce losses. This pressure is less than combustion, so it could let some oil be consumed... And the AFM system runs on a cycle (not really applicable here, but a fun-fact)...it'll never run indefinitely so that the engine can maintain safe levels of temperature spread across parts, and lubrication, etc... |
02-21-2017, 04:37 PM | #14 |
Drives: 2017 2LT V6 Join Date: Nov 2016
