02-21-2017, 10:17 AM | #1 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Jacking pucks
What have you guys found that works? I see fancy aluminum magnetic ones for $$$$$ and ones that look similar to a hockey puck that are much cheaper. What did you pick and why?
02-21-2017, 10:20 AM | #2 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
I picked the permanent (semi) mounted ones from ZL1 addons. I don't have to worry about finding it, taking it with me, or anything. They're super convenient, and you can use them with the jack and/or jackstands. Also, you can't even see them when they're installed.
02-21-2017, 11:53 AM | #3 |
Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
I picked up the pucks first since they were cheaper. The problem with the pucks is that they are too wide and in the back will press against the sideskirt. The ZL1 Addons magnetic one has two raised thin rails (as opposed to a slit cut into a puck) to avoid that.
02-21-2017, 11:59 AM | #4 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
Spent like $10-$12 and made a set of 5 up out of actual hockey pucks... Perfect size (had to bolt 2 together to fully support the seam)
02-21-2017, 12:33 PM | #5 |
Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
https://zl1addons.com/collections/ja...-with-mag-puck
Where I got mine |
02-21-2017, 12:51 PM | #6 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I just bought the cheap ones on Amazon and they work perfect. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
02-21-2017, 01:07 PM | #7 | |
02-21-2017, 01:16 PM | #8 |
#becauseracecar
No. I have to line them up as I'm putting the jack in place. I also have to use a small block of wood below them in the concave of the jack so that the jack does not contact the rocker molding when I go to lift it up but this would be the case with any jackpad with a full size jack with a concaved jack area.
02-21-2017, 04:50 PM | #9 |
Thanks!
02-21-2017, 05:10 PM | #10 | |
02-21-2017, 05:19 PM | #11 |
#becauseracecar
It just barely fits if I push it all the way inboard. It is tight though.
02-21-2017, 05:43 PM | #12 |
Definitely a little pricier but works really well.
