11-20-2013, 01:50 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Feb 2013
driving without a hood?
So i found a hood I want to buy and its about an hour away, but I don't have a truck. How dangerous would it be if I took my hood off and were to drive to pick up the other hood, installing it when I got there? Keep in mind that I would have to drive on the highway. Sorry if this is a retarded question, but I have no other solution to getting this hood
Appearance: Blacked out tail lights, Oracle Plasma fogs, SLP Carbon Fiber splitter, Carbon Fiber Hash Marks, Carbon Fiber ZL1 hood, 20" Giovanna Kilis rims, Eibach lowering springs Performance: Straight-piped magnaflow exhaust, K&N intake |
11-20-2013, 01:56 PM | #2 | |
Drives: 2014 camaro ss ,1967 chevelle ss, Join Date: Sep 2013
Maybe take engine cover off and that should be it |
11-20-2013, 02:01 PM | #3 |
Drives: 2010 Camaro SS! Join Date: May 2009
Not illegal in Florida, and it shouldn't effect your engine at all (long as your not driving through a hail storm or a hurricane).
1SS ABM Manual, Black int., 20" PAWs, Sunroof
$$ down on dealer car #3466, pending Pw: 6-10-2009 Car Picked up by Shipper: 6-22-2009 Car has ARRIVED: 6-24-2009 (and she's a beauty!) |
11-20-2013, 02:11 PM | #4 |
Drives: 2010 Camaro 2LT RS, 2009 GTR Join Date: May 2009
Only problem is weather
Build thread: http://www.camaro5.com/forums/showthread.php?t=152335
Photos: www.flickr.com/bradbeer GTR Instagram: @NoCrustGTR |
11-20-2013, 02:14 PM | #5 |
Drives: 2018 GT350 Join Date: Nov 2011
I'd stay off highways as something could get throw back and hit something on the top of the motor.
Off to the Dark Side
11-20-2013, 02:20 PM | #6 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
The real question is it a steel hood with the bolt holes tapped and if you know how to properly shim and align a hood? If it is fiberglass etc it may not want to mount right away without some prep work, and it had better come with all parts included to be able to attach it and have it lock closed properly if it does not have you transferring parts from your hood....?
11-20-2013, 02:21 PM | #7 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
You might also want to check and see if your new hood needs hood pins, or if they are recomended- don't want your new hood flying up to meet you.
Also when removing, use two people- it is so easy to slip and crack your windshield.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
11-20-2013, 02:37 PM | #8 | |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
11-20-2013, 04:50 PM | #9 |
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Oct 2013
rent a small u-haul truck or a pickup truck from your local Home Depot
Hurst Short Throw Shifter, K&N CAI, SRP Racing Pedals, GM Performance Exhaust, GM GFX Package
Lakewood Strut Tower Brace, JBA Shorty Headers, JBA 8 MM Wires, Airaid TB Spacer, Phastek CAI Scoop, Washer Bottle Relocation Kit, Stainlees Steel Brake Lines, Brake Performance Slotted and Drilled Rotors, BMR Tunnel Brace, BMR Trailing Arms, BMR Subframe Connectors, Borla ATAK Muffelers, Z28 Wickerbill Spoiler, VTC, Bow Tie Delete, BMR Adjustable Front Swaybar, BMR End Link Kit, BMR Extreme Rear Anti-Roll Kit, Diablo I1000 "InTune" |
11-20-2013, 07:40 PM | #10 |
Adam E. Lucchesi
Why not just ride down there as normal and remove your old hood when you get to the destination and then install the new one right there? Seems logical to me...
11-20-2013, 07:43 PM | #11 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
How does he get the old hood back to his Crib?
11-20-2013, 07:43 PM | #12 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
No longer than that shouldn't be a problem in good weather. But as others have said make sure you get or have everything needed to properly install it.
The Bird is the word! |
11-20-2013, 07:44 PM | #13 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
How would he get his old hood home?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
11-20-2013, 07:47 PM | #14 |
Adam E. Lucchesi
