Old 12-11-2023, 01:59 PM   #29
Katech_Mike
Drives: 2015 Camaro ZL1
Originally Posted by CamOnlyJabroni View Post
That's 1320hp at the flywheel correct? I believe this was done on an engine dyno. Originally on Facebook I thought it was WHP.
That is flywheel correct. We will test on the chassis dyno as well when we get to that point.
Katech_Mike is offline   Reply With Quote
Old 12-11-2023, 02:17 PM   #30
Katech_Mike
Originally Posted by rcoe View Post
This still looks to be a very expensive path compared to current port injection systems not to mention the upcoming DSX.
What would be the benefit to going this route vs. port injection?
The current cheapest/most popular PI route looks like this.
THP port plates -$750-$850
THP Reflex - $1,200
AEM wideband for live feedback - $170
THP low profile lid for hood clearance - $1,200-$1,300
Injectors - $500
Fuel lines for port rails - $200(estimated)
Total - $4,020-$4,220
This doesn't include the additional labor to wire the controller or wideband, mount the controller, run the harness, install the port plates & injectors, and make the fuel lines. Or the added complexity of running and tuning a secondary controller.
Our pump and +30% injectors will require virtually no additional labor when doing a heads/cam job and will be competitively priced. It will be 100% controlled and tuned by the factory ECU with no added complexity.
Not to mention its been proven that DI makes more power than PI. As long as you can properly fuel it of course.
It won't be for everyone but it should cover what about 90% of people are trying to do with this platform.
Old 12-12-2023, 09:02 AM   #31
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If you are just clipping 130 degree pump angle up top at 1300hp with turbos what do you think the limits would be with a belt driven supercharger?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 12-12-2023, 11:37 AM   #32
JANNETTYRACING
JANNETTYRACING's Avatar
Really looking forward to getting our hands on one of these.
Question for you, What pressure are you running the 65% over injectors to meet that power level.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-12-2023, 12:53 PM   #33
Katech_Mike
100hp less roughly. We will test it in a vehicle with a Magnuson 2650 as that's the most common power adder on this platform.
Old 12-12-2023, 12:54 PM   #34
Katech_Mike
Ted.
2,700psi max when using +65% injectors
Old 12-12-2023, 01:11 PM   #35
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
We're still in the testing phase. Everything so far has been VERY promising.
We made over 1,300hp with turbos and full E85 on the engine dyno.
We made 1520hp on C16 with <100° pump angle when the inercoolers would no longer keep up.
LT4 injectors will operate at 3,600psi. We have been doing it for years. +30% injectors are stable to roughly 3,200psi and +65% are stable at 2,700psi.
Cost will be less than the LPE but do not expect it to be 50% less.
We're talking about XDI's injectors here, right?
Old 12-12-2023, 01:29 PM   #36
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I caught that too. Since XDI is the only ones making +65 injectors, I assumed as much. The FIC +30 will not handle 3200 psi, ever lol.
Old 12-12-2023, 01:39 PM   #37
Katech_Mike
Correct. We currently exclusively use XDI for our DI injectors. They have proven to be the most reliable and best performing injector for us.
Old 12-12-2023, 02:33 PM   #38
JANNETTYRACING
That is where I landed as well.
Old 12-17-2023, 04:31 PM   #39
JSH
JSH's Avatar
Drives: '20 ZLE
If this pump will hold 2900 psi with 30%+ injectors at 6ms
My OEM holds 2800 at 5.4ms on 30+. I'm surprised these differences would matter that much. And I do need more hpfp for race gas.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 12-17-2023, 04:39 PM   #40
Joshinator99
Race gas is much easier to do that with than E85…. Apples and oranges.
Old 12-17-2023, 07:21 PM   #41
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
On E85 with stock cam fuel lobe?
Old 12-17-2023, 08:09 PM   #42
JSH
JSH's Avatar
Drives: '20 ZLE
No, race gas on 32% fl. Anxious to see how my new build does on OEM HPFP. I would buy this new pump if it was worth it.
'20 ZL1 1LE A10,
