04-04-2023, 03:50 PM | #29 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Turns out the duty cycle on the port injectors was getting too high so they swapped those for some larger, extended tip injectors. Just to recap, the car has a big bore pump (38% lobe), +30 DI injectors, and had 1000cc PI injectors.
The new injectors likely changed the spray pattern as they are now flush with the THP plates vs ~3/4” inside. Slight HP increase in 6th gear, but importantly, more power under the curve. I’d disregard the torque numbers as I don’t believe that is correct.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
04-04-2023, 04:14 PM | #30 |
Wow, 1600 lbs of torque.
04-04-2023, 04:18 PM | #31 |
Yeah, I think something is not right there. It’s the first time they’ve ran torque number on my car using that dyno.
04-04-2023, 09:45 PM | #32 |
You running this weekend or next?
04-04-2023, 10:01 PM | #33 |
Definitely next weekend but might try to squeeze something in before.
04-05-2023, 08:30 AM | #34 |
Petro-sexual
Good Lord. That's crazy.
04-05-2023, 04:43 PM | #35 |
Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
Do you remember how much the 120mm TB/snout added?
04-05-2023, 05:00 PM | #36 |
So you're launching in 2nd with nannies off and using the manual mode's auto shifting feature. Have you found yourself short shifting the 2/3 due to tire spin?
'20 ZL1 1LE A10,
04-05-2023, 05:23 PM | #37 |
I don’t. We never did an A/B test with just that being the change. I’ve heard it’s only 10-15 RWHP over the 112mm though. Perhaps it becomes more the faster you spin the blower, but can’t say for sure.
Yes to launching in 2nd, but I do not turn off stability control. Traction control is off. It typically doesn’t spin once I leave the line. It has happened a couple times, but it’s not a regular thing.
04-05-2023, 05:56 PM | #38 |
And you're launching from idle to WOT?
'20 ZL1 1LE A10,
04-05-2023, 06:47 PM | #39 |
No, I’m leaving around 2k RPM in 2nd gear and easing into boost with Smooth Boost. Prior to that we’d ramp spark.
04-05-2023, 06:59 PM | #40 |
What is smooth boost?
'20 ZL1 1LE A10,
04-05-2023, 07:07 PM | #41 |
It replaces the vacuum based bypass actuator with one that can be electronically controlled by throttle position, time, etc.
04-05-2023, 07:33 PM | #42 |
Whole thread on it when I added it last year…
https://www.camaro6.com/forums/showt...ht=Smoothboost
