05-30-2019, 08:37 PM | #15 |
Drives: 17 SS a8 Join Date: Feb 2010
that map is for the compressor. I am guessing the tial housing is for the turbine side(exhaust side). that is a whole other map. they may have charts for those too.
that turbo will make a ton of power for you. if you pick a turbo that puts you in the middle of the map you end up going really large and it is laggy.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
05-30-2019, 09:01 PM | #16 |
Drives: Turbo 6.2 Join Date: Feb 2019
^^^ duh, i forgot that was the compressor side you guys were talking about. im going to agree here. Frumusa Performance tested all three SS turbine sizes tial offered and the best performing hot side is what they stuck with.
I dont believe the cold side was tested against others but im sure itll sing enough for me and the family to cruise around in.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 Last edited by Choda; 01-20-2020 at 12:16 PM. |
05-31-2019, 09:37 AM | #17 | |
Engine arrived!!!
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 Last edited by Choda; 05-31-2019 at 01:15 PM. |
07-26-2019, 12:22 PM | #18 |
Engine looks great, replacement parts are being ordered and long block is being assembled. Hoping to get some miles on it mid Aug and get to the track by the end of the month.
Heres my Uncle Rodney and old heads. They have a little damage but I'm hoping i can find someone that could use them.
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
07-26-2019, 01:51 PM | #19 |
Is this the second new motor?
07-26-2019, 02:43 PM | #20 |
Drives: SS 6 speed of course Join Date: Jan 2016
makes you wonder why everyone has above .600 lift cams when the head flat spots at .600...
07-26-2019, 02:49 PM | #21 |
no no lol
I popped the original motor when I made the thread, we are piecing the new forged motor together.
08-19-2019, 07:51 AM | #22 |
late update
Everything went back together nicely. fired right up, no issues but it was pouring out so the car hasn't been driven yet. With the lower compression and new heads im going to play it safe and let the tuner take another look at it. Were going to leave it at 10psi and see what it does. Stay tuned for upcoming track times and dyno numbers.
08-20-2019, 08:24 AM | #23 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
08-20-2019, 09:26 AM | #24 |
PM'ed you his email.
08-20-2019, 11:54 AM | #25 |
Glad you got it back together ok. I lowered mine also to 10.5, we haven't seen any detonation in the logs whatsoever. I feel like I made the right choice on that decision. We will port the heads this winter and match the blower ports also.
08-20-2019, 12:59 PM | #26 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I just put a down payment on an upgraded short block and cnc ported lt1 heads from gtrain on here.
Short block: - brand new GM LT1 Engine*Block - Stock wet sump Crankshaft - Manley H-Beam Rods - Manley 2618 Pistons 10.5:1 compression - ARP Rod Bolts - Premium Total Seal Rings - Clevite Bearings - Professionally Balanced - ARP Main Studs That's just about the exact same short block you've got, isn't it Greg?
Baby Blue
08-21-2019, 08:26 AM | #27 |
engine is broken in
oil change new plugs checking tune did you notice any difference in power/drive ability with the decrease in compression? Am I safe to assume my car will make less power with the new engine leaving everything else the same?
08-21-2019, 09:39 AM | #28 |
less compression equals less power...you make that up by increasing boost.
2016 NFG 1SS A8
