10-14-2016, 04:28 PM | #1 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
Race Ramps
I am looking to order some race ramps to make working on my lowered 5th Gen Camaro & my already low enough 2015 Nissan 370Z. Anyone have experience with these? I looked on the site & am not sure which is the right product for me. I'm thinking I need the extenders to make the ramp more gradual especially for the Z, but not sure how much height I need to comfortably work. I am also thinking about getting the storage ramps to prevent the tires going flat-sided especially over the winter. Any input/experience appreciated.
10-14-2016, 06:30 PM | #2 |
Drives: 2010 ss Join Date: Oct 2015
get the 10" ones with the long 67" ramps.best ramps,well worth the money,my 2010 ss goes right up no problems
10-14-2016, 07:12 PM | #3 |
I have these as well. Work great!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-14-2016, 10:54 PM | #4 |
Drives: 2SS/RS Join Date: Sep 2008
I bought these and absolutely love them. https://www.amazon.com/Race-Ramps-RR...e%2Bramps&th=1
The two piece is great for when you have to get to the side of the car. To determine if you need the extenders or not do the yard stick test. Push one end of a yardstick up against the edge of either front tire. Raise the other end of the yardstick until the yardstick just barely touches any part of the car anywhere along the length of the yardstick. Don't bend the stick since this will produce an incorrect test result. Using a tape measure or suitable ruler, measure the height of the yardstick at the tip of the raised end (the 36" mark). If this height is at least 7.25" then you don't need extenders. If the height of the raised end of the yardstick is less than 7.25" but more than 5", then you will need extenders. |
10-17-2016, 05:01 PM | #5 |
Drives: T Join Date: Mar 2015
I'm lowered 1.5 all around and we have race ramps that I use to check turbo stuff and change oil. Works really good for my c5 corvette which is extremely annoying to get under neith.
Race ramps are definitely a good buy |
10-17-2016, 05:37 PM | #6 |
Race Ramps
It was hard to justify the price but yea....i love them and would purchase them again
Definitely do the 2 piece ones Sent from my iPhone using Tapatalk |
10-17-2016, 05:53 PM | #7 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Use mine all the time
Little tip. Got mine right before Christmas a few yrs ago. Summit had them at a great price I think around Black Friday. Sent from my iPad using Tapatalk
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
10-19-2016, 07:58 PM | #8 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
I have these as well and they're great! I bought mine from Summit Racing.
10-25-2016, 12:31 PM | #9 |
1,425 hp / supercharged
Drives: (2010 2SS/L99) (1999 Corvette) Join Date: Oct 2009
They are the best ramps I've ever owned. Highly recommend them for cars with low ground clearance.
"If it's too loud...well, you know the rest."
12-22-2016, 06:36 PM | #10 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Got em, love them. I'm lowered and have the zl1 bumper with a splitter extension. Work great...
Also have their flat stoppers.. -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
03-30-2018, 03:43 PM | #11 |
Drives: 2012 45th Anniversary Camaro Join Date: Feb 2018
Race ramps
Just got my Race Ramps delivered today and they are worth every penny!!
09-09-2018, 01:28 PM | #12 |
Drives: 2015 Camaro 2SS/RS Join Date: Jan 2007
They don’t dig into asphalt right?
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune Kooks LT/HFC/Xpipe/NPP Mufflers 4:10's, Trutrac Solid Cradle Bushings, BMR Toe and Trailing arms |
09-09-2018, 03:45 PM | #13 |
Native Floridian
No they won’t. They’re flat on the bottom and will not dig into anything.
11-16-2018, 02:24 PM | #14 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Do they tend to slide when you drive up on them on smooth concrete? Or is the ramp incline such that it is not a problem?
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
