Old 01-18-2021, 12:16 PM   #127
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by Texan4iu View Post
Indiana Jones, right?
The Ark of the Covenant- you are correct sir!
BTW the Royal Purple gear oil shifts like butta.
Ventmaster is offline   Reply With Quote
Old 01-25-2021, 02:43 PM   #128
L78toLT1
L78toLT1's Avatar
Originally Posted by MatthewAMEL View Post
BTW - Tremec mentioned that they do not require the 8oz drain out procedure if you use their fluid. That is for the expansion properties of ATF.
The Tremec fluid is almost clear. And it doesn't smell horrible like ATF.
Tremec must have changed their tune regarding using their fluid in the TR-6060. When I emailed them a year or so back, they recommended the oem ATF over the Tremec fluid.
Baby Blue
Old 03-25-2021, 03:26 PM   #129
Drizzt ss
Drizzt ss's Avatar
Drives: 2017 NGM 1SS MRC NPP
Can anyone help me out here? Which is it? I took a pick of the black bottle a while ago, is it still the same recommendation from GM? I want to put what’s recommended while still under warranty. And thanks for all the info! I’m going to attempt this in my driveway on stands, that should be interesting haha
Mamo PTB /Borla ATAK NPP /Carbon Fiber lip/ZL1 side skirts/ Black Bow ties/Husky Mats/ Mishimoto CC /BMR strut tower brace/ZL-1 License relocation/Rock guards
Drizzt ss is offline   Reply With Quote
Old 03-27-2021, 01:18 PM   #130
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
88861800 is what the 2016/2017 owners manual states and what the 2016/2017 service manual states as the correct OEM transmission fluid for the TR6060 manual transmission.
--KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 04-20-2021, 03:45 PM   #131
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Hey All,
I don't mean to beat this to death. But, can someone clarify / verify the required amount of fluid needed to do this flush and refill? The reason I ask is because the OP states in the (awesome) instructions that you'll need 3.65 qts. However, JCunningham (post 117) stated that it takes 5.2 Qts. I just want to make sure that I'm not missing something..
also, are you suppose to fill it, start / drive the car, then go back and check the fluid to see if any/some was consumed through the nooks/crannies?
Thanks everyone!!
SHE'Z 18 is offline   Reply With Quote
Old 04-20-2021, 10:37 PM   #132
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Originally Posted by SHE'Z 18 View Post
Hey All,
Thanks everyone!!
If you want to drain and fill, that's ~4qts.
If you want to FLUSH (drain/fill/drain/fill) in order to get the most fluid exchanged (out of the cooler and lines), then you need more.
The fill and drive is for the diff. You don't use that technique for the Transmission.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 04-21-2021, 11:36 AM   #133
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Thanks Matthew!!! And to all the others for great instruction, tips and tricks.
I'm now looking forward to getting this completed.
Old 06-13-2022, 02:26 PM   #134
atx_traveler
Drives: blue velvet
Just did a transmission fluid change with Redline D4. Feels great again. I last changed it 10k miles ago, also with Redline D4. I'm curious if this will stay feeling good longer, as more of the original fluid is changed out.
atx_traveler is online now   Reply With Quote
Old 10-27-2023, 10:00 PM   #135
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
pump into it until it leaks out, start car for 2 mins(?), suck 8 oz out, tighten plugs
or
pump into it until it leaks out, suck 8 oz out, tighten plugs
havelegs is offline   Reply With Quote
Old 02-19-2024, 10:28 AM   #136
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf GTI
What does everyone use to pump their fluid into the trans? I found a gereric hand pump on Amazon for the diff fluid but it would not screw onto the ACDelco quart bottle. Does anyone have a link to one that will fit?
Also is this the correct ACDelco fluid for the trans in a ‘22 6MT ZL1? The only reason I’m confused is because of the “H” designation. My manual just states Dexron III.
Also how many of you drained the trans from the back drain vs the temp sensor? Thanks all.
’22 ZL1 Riverside Blue 6MT
’15 GTI Carbon Steel 6MT
PowerDemon is offline   Reply With Quote
Old 02-19-2024, 04:14 PM   #137
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
This is what I use, it’s a lifesaver:
https://a.co/d/bVf1xca
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 03-07-2024, 11:38 AM   #138
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
I'm having myM6 fluid changed today. What is the reason for the level to be 1/8 below rather than at the bottom of the fill hole?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 03-23-2024, 10:48 PM   #139
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
The fluid expands when hot and will get ejected via a vent at the top of the trans. In my experience this only happens with track use. Once enough fluid (a teaspoon here and there) is expelled it stops.
So if you fill to the fill hole, let it completely stop dripping before you put the fill plug back in. After that you *may* see some small puddling of trans fluid until it burps out the surplus, which is harmless. This only if you get the fluid really hot. Hot = 180-200F.
IMO the 1/8" below the fill hole is to prevent the dealer visit if some spirited driving is done and the owner happens to notice a small drip under the car.
wakespeak is offline   Reply With Quote
