Old 06-11-2016, 11:04 PM   #1
tward
tward's Avatar
Drives: 99 Corvette, 68 Camaro, 03 350Z
Removing The Airbag Warning Stickers
WARNING: Do not perform this modification if you are worried about the following...
  1. You are afraid of going to federal prison for removing these airbag warning stickers and/or mattress tags.
  2. Being killed by your airbags, because you won't be able to read the warnings before starting your Camaro.
  3. In 50 years you will need to find reproduction stickers to return your Camaro back to concourse condition.
  4. You think it a lot of work for something that you never even notice.
Step 1: Using a hair dryer on high heat, carefully warm the warning sticker to loosen the adhesive. After a couple of seconds, begin to pull a corner of the sticker from the visor. Continue blowing hot air on the sticker as you slowly pull it from the visor.
I tried pulling on the warning sticker without heating it up first, but it was stuck on pretty tight and I was afraid I would stretch out the fabric on the visor.
Step 2: To remove the adhesive that has remained behind on the visor fabric, spray adhesive remover (Goo Gone) onto a microfiber towel and scrub the visor. Heating the area as you scrub seems to help.
Step 3: Once the adhesive has been scrubbed off, clean the area with a mild soap and water solution to clean the adhesive remover from the fabric.
Step 4: Dry the area using a clean towel and/or the hair dryer.
Step 5: Add the airbag warning stickers to your mattress tag collection.
2016 Camaro 2SS: Garnet Red Tint Coat, Jet Black Interior, A8 Auto, MRC, NPP, Nav and 5-Split Spoke Silver Rims.
tward is offline   Reply With Quote
Old 06-12-2016, 06:52 AM   #2
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Great info. Thanks for sharing.
Old 06-12-2016, 08:42 AM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
An alternative if you trade your car often; cut two pieces of 3M Dinoc carbon fiber vinyl from Amazon and stick it on over the labels. It peels off easily and the car looks 100% stock when you trade it. It also takes 10 seconds .
Old 06-13-2016, 07:18 PM   #4
5150 Maro
5150 Maro's Avatar
Drives: 2018 ZL1
These are available for $13.99 from RPI Designs
http://www.rpidesigns.com/shop/item....-label-covers/
2012 2SS/RS 45th Anniversary Edition 2012 to present
2010 2SS/RS Summit White 2009 to 2012
1998 RS V-6 Silver with T-tops. 1998 to 2000
1993 Z28 Red Wrecked (twice) 2014 to 2016
1988 RS Blk lowered custom rims 1988 to 2000 Stolen
1976 LT Ruby Red 1976 to 1988 (He's dead Jim)
5150 Maro is offline   Reply With Quote
Old 01-28-2020, 09:28 AM   #5
blackmosaic16
Drives: 2016 2SS Convertible
To resolve not only the ugly sticker issue, but the uncovered mirror issue, I'm pulling mine and fabricating leather covers. I'll post pics when done!
blackmosaic16 is offline   Reply With Quote
Old 07-23-2023, 03:08 PM   #6
7Merlin
Drives: 2023 2SS Red Hot Convertible
I peeled one of mine off without first researching .
Any suggestions on how to stick it back? (I'd rather put black sticker on top). I'm thinking double sided tape but now sure how it will work
7Merlin is offline   Reply With Quote
Old 07-24-2023, 06:57 AM   #7
NashZL1
Drives: 2022 Camaro ZL1
Another alternative to hide them:
https://sunvisorsolutions.com/
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2016 Hyundai Equus Ultimate
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 09-22-2023, 05:15 PM   #8
7Merlin
Update on my woes with this. Double sided tape doesn't hold, peeled off after a while. I tried sticking the vinyl cover from RPI designs in the spot where the original sticker was and the vinyl doesn't hold more than a couple hours in warm weather.
I'll try removing the glue that was left with goo gone now... and keep the original sticker to stick it back in the future if I wanna restore it to stock
Old 09-22-2023, 06:06 PM   #9
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I ripped mine off because I couldn’t stand them. the only thing I can think is trying to iron it back on with a low heat setting to reactivate the glue. Try with a thin damp cloth between the iron and decal
Old 09-22-2023, 06:34 PM   #10
mpride
Drives: 2022 Camaro SS 1LE
I went this route. Matches perfectly and very simple to put on.
Mark
Sugar Land TX
2022 VOM Camaro SS 1LE
mpride is offline   Reply With Quote
Old 04-11-2024, 09:45 PM   #11
Camby
Camby's Avatar
Drives: 2023/2SS/1LE/RadiantRed/A10
I did this. It takes time and patience. Do it over several days so you don’t get frustrated. Don’t overheat and don’t scrub at glue too hard. I removed each visor and took my time on my workbench. It’s so worth it. Makes the cab much darker without that highlighter in your face. I tried the black tape too, but didn’t like the censored look.
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
Camby is offline   Reply With Quote
Old 04-12-2024, 06:01 AM   #12
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Wonder if a hand steamer would make it a bit easier?
Might have to take one out and try it this weekend after I futz with the OnStar bs.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
