Vararam
Old 09-22-2015, 11:37 AM   #1
Bodywerks
Drives: 2015 2SS/RS/1LE
remove rear O2 sensors after headers n tune?
Pretty straight forward question. My understanding is the tuner takes the rear o2 sensors out of the equation to prevent check engine lights, etc. So can I just remove them entirely?
Why would I want to do that, you ask? I'm going from high flow cats to catless mids when I do my heads n cam. I'd rather not fight those sensors again and risk damaging them. I'd instead rather just install a bung plug and be done.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 09-22-2015, 11:54 AM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Yes, if he turns the rear o2 DTCs off, the code will not appear. Plug the hole and call it good. Dont forget to cap the socket with something so water doesnt get in there. It is still live.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 09-22-2015, 12:01 PM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Or you could leave them in and hooked up ,to give the impression nothing has been tampered . This and HF cats give the car a legal/legit look to prying eyes.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-22-2015, 12:44 PM   #4
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
it's technically just as illegal to run a non OEM cat on any registered vehicle that is less than 5 years old as it would be to just running no cats. So this guy has a 2015, not 5 years old. You'd get in just as much trouble if you had high flows or no cats from a "legal" prospective
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 09-22-2015, 12:53 PM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
no need for them cap them. you could probably order pipes without the o2 bungs. If I ever have to replace my Cats ill tell ARH not to put them in.
Old 09-22-2015, 02:31 PM   #6
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
That's why I have high flow cats. You'll likely fail emissions inspections in NC without cats, but with cats (OEM or not) you'll pass.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 09-22-2015, 02:44 PM   #7
GONIF
GONIF's Avatar
Yes I know that , I'm an emissions tec. Just saying it would look ok to the untrained eye.
Old 09-22-2015, 08:09 PM   #8
Bodywerks
Thanks for the replies. This is good to know.
As far as emissions, in pima county AZ, the current emissions testing is to check for DTCs/check engine light and that's about it. Plus, I don't have to worry about that for 4 more years. Who knows, I may be TT 416 by then!
2015 SS/RS/1LE
Old 09-22-2015, 08:11 PM   #9
candoege
Drives: ford
candoege is offline   Reply With Quote
