09-14-2015, 01:03 PM | #1 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Want to Confirm I can replace ZL1 Calipers with AC Delco CTS-V Calipers
Looking to put yellow calipers on my ZL1.
Ideally I would like to have a second set painted yellow rather than painting the existing calipers. That way if I don't like the yellow I can easily revert back to the OEM color. Problem is to purchase a second set of ZL1 calipers new is going to cost around $3600. Yikes! I see were Amazon sells yellow AC Delco CTS-V calipers (part#172-2521, 172-2522) for $289 each for the fronts and $183 each for the rears. Quite a far cry from the cost of the OEM ZL1 calipers. Now all my research says you can swap the ZL1 calipers with the CTS-V calipers from the '09 and up model years. Can anyone confirm this? If indeed this is true, then my other question is why are the AC Delcos so much cheaper? Obviously for safety reasons I don't want put a replacement caliper on that will diminish the car's braking.
09-14-2015, 02:38 PM | #2 |
Drives: 14 1LE Join Date: Mar 2013
They are the same. The rears you will have to put the cross over tube on the other end but other than that they are complete bolt on. No idea why they are so much cheaper.
LMS Engineering
09-14-2015, 04:58 PM | #3 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Probably because GM doesn't sell a upgraded brake kit for cadillacs but they do sell a retail version of the ZL1 brakes for the SS, so cha-ching! lol
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
09-14-2015, 06:01 PM | #4 |
Drives: cars Join Date: May 2011
09-14-2015, 08:22 PM | #5 |
That is glorious looking, unfortunately I get the feeling that pretty color won't last long on the track.
My stock SS brembos are pretty much a nice silver color now, lol.
2010 2SS
09-14-2015, 08:59 PM | #6 |
They're a yellow with salt and pepper contrast from embedded brake dust now. Haven't seen any discoloration, I figured if yellow "yellows" from heat then whats the worst that could happen. I will be rebuilding with vented pistons this winter since I've cooked the seals pretty bad.
09-14-2015, 09:26 PM | #7 |
Coupe Newbie
Sweet! Thanks for confirming.
09-14-2015, 09:31 PM | #8 |
Coupe Newbie
Definitely don't want the mustard color. I like the velocity yellow. Did you explore any other shades of yellow?
09-14-2015, 09:32 PM | #9 | |
Are there better seals out there if I wind up having to rebuild my calipers? I'm sure it will happen eventually if it hasn't already, nothing seems to be leaking though currently.
2010 2SS
09-14-2015, 09:37 PM | #10 |
09-14-2015, 09:40 PM | #11 |
Coupe Newbie
I don't track my car so I don't think I'll have an issue with the color changing from excessive brake heat. Now I am concerned that brake dust will make the yellow color always look dirty.
09-14-2015, 09:40 PM | #12 | |
09-14-2015, 09:42 PM | #13 |
If you dont track then ceramic pads and a clear coated caliper are all you need. Although darker colors will hide dust more. I've remelted the powdercoat on the track so embedded will happen.
09-15-2015, 08:36 AM | #14 | |
Drives: 2010 2SS/RS Join Date: Jul 2014
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs.... Use to have 2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's |
