12-11-2016, 01:39 PM | #43 |
Drives: 66 Chevelle SS Join Date: Mar 2013
What was the ride height at the "Ring"? That car performed pretty darned well and is high on the pecking order. Sometimes a certain "look" is counter productive. That said, Chevy has to design a car knowing that not all of their customers knows how to drive their car.
How much down force is placed in this car at speed? |
12-12-2016, 05:43 AM | #44 | |
Drives: 2017 Camaro ZL-1 Join Date: Sep 2016
So I finally got the car out and drove it about 60 miles Saturday. I am trying to limit the miles as it is going to the performance shop on Tuesday (for some other goodies ) and they are going to check the alignment to verify. From what I can tell IF the camber was changed at all it was exactly equal between driver and passenger sides as there was no pull one way or another. First impression, the ride is a little stiffer which is what I expected. Lets just say I had a '14 1LE and before the lowering springs on the '17 I would say the ride was 100x better than the 1LE. Now it is maybe 85x better than the 1LE. So for me, still not bad and well within the realm of driving a sports car (the gen 6 has surpassed muscle and pony car status IMO).
I noticed there was a couple questions about linear vs progressive for the springs used. The BMR springs that were used have linear spring rates. Quote:
There are some considerations to be taken into account though. With the front lower the overall balance of the car has been shifted forward. What does this mean? Well possibly a little more under steer going into a corner. But the resulting exit of a corner will be better because the weight can transfer to the rear and "level" the car out. Now the MRC, please read my previous post about the Vettes and the chassis engineer. I also forgot to mention these dampers are now also going to be used on GM pickups, let that sink in for a minute. After I posted the other night I continued to do research, and found that Ferrari used MRC in one of their California's. That particular car could be lowed over 1.3" using factory installed equipment with no issues, which sounds oddly familiar to the Vette. On a couple forums there was even suggestions that the MRC could actually handle ride height changes better than standard dampers due to the way they operate. With all this being said and the hundreds of forum posts, BWI and Delco pamphlets I've read, I doubt there will be any harm done to the dampers, and as long as it isn't slammed to the ground there shouldn't be any issues. I truly could not tell the difference last night and believe the only way to do so would be to have two at a track that you got out of one and directly into another. I honestly don't think even then 75% of us would feel the difference. But that is just my opinion. Until I get some more miles... |
12-12-2016, 07:36 AM | #45 |
Drives: 2017 ZL1 Nightfall Convertible M6 Join Date: Nov 2016
I do like the lowered look but it all just sounds like tweaking the engineering recipe without an accurate way to measure the effects. 85% here 75% there.... If we are being honest about this, the reason you lowered the car is for looks and the resulting performance effect is unlikely to be an improvement. I'll be keeping mine stock.
12-12-2016, 07:56 AM | #46 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Thanks for the update Woody!! Keep us posted. If the lowering springs had the same spring rate as factory but was just a little shorter, it would lower the car without changing the ride quality at all, other than any difference a lower cg might make. That would be my preference if anyone knows the factory rates and length before it's installed on the strut. I wish the car just had adjustable ride height front and rear like the Vettes and Ferrari.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
12-12-2016, 08:07 AM | #47 | |
I used to be Dragoneye...
(And since we're wishing things....I wish it came from the factory super low to the ground, but equipped with a front lift system like Porsche offers ) |
12-12-2016, 08:15 AM | #48 | |
Drives: 2017 ZL1 "Scarlett", 6 spd. Coupe Join Date: Mar 2012
All my life I've been an Adrenalin Junkie.To some thats a bad thing.But? My bucket list is very short, very short indeed
12-12-2016, 08:58 AM | #49 | |
12-12-2016, 09:10 AM | #50 | |
12-12-2016, 11:56 AM | #51 | |
We lowered my 2012 ZL1 buy about an inch and a quarter. The front springs did not have a high enough rate, and if I hit a big enough bump in the road, the front suspension would hit the stops...hard. MRC does not, in any way shape or form...act like a spring, or provide any mechanical limitation to the distance of suspension travel. They are simply dampers...literally damping the motion of the springs during compression and rebound. It just so happens that they can alter the rate at which they do that...which is how Chevy and other brands tune in the magic. The only thing that will stop the suspension from bottoming out, if the springs aren't right, are the bump stops. And it's not pleasant when you hit those. I appreciate the positivity in here regarding the feasibility of dropping the car. One good sentiment (which also included a lot of caveats), does not make it the rule. I want it to be easy, too....but it's not. Lots to think about... |
12-12-2016, 11:58 AM | #52 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
would some sort of body kit be easier?
12-12-2016, 12:33 PM | #53 |
As far as eliminating the fender gap, yes it would. Someone could make fender moldings like GM used on the 5th Gen Z28 to take up the gap in front. The trick would be making the rear match. You wouldn't want to take up any more gap in the rear, but you would want the molding to be the same height. Most would probably want the moldings painted to match the body as well, so then there's that concern.
12-12-2016, 01:31 PM | #54 | |
12-12-2016, 01:41 PM | #55 | |
And you've got to remember...while the dampers do help...they aren't calibrated to do that, nor account for less travel in the springs. |
12-12-2016, 02:27 PM | #56 | |
Drives: 2023 Camaro ZL1 Join Date: Jan 2016
Flame away but I wouldn't touch the suspension on a car that does the Nring in 7.29 from the factory . . . unless I was building a dedicated racer. |
Tags |
lowered, phastek, phastek performance, zl1 |
