Old 02-12-2017, 11:23 AM   #1
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Power Stop Z26 Brake Pad Review (Cut Down the Brake Dust)
Put the Power Stop Z26 brake pads to the test to mainly get around the stock pad dusting. But they perform on par with the stock pads and basically cut the dust down A LOT.
Sledgehammer70 is offline   Reply With Quote
Old 02-13-2017, 09:58 AM   #2
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
Hey Sledge,
I watched your install video as well. I'm convinced I also want to replace my pads & the Z26 looks to be a good option. Thanks for the review.
When removing the caliper pins to get the Brembo pads out, it looked like you just used a punch to get them out. There is nothing holding them in place or nothing to unscrew or anything? What holds them in place during normal use?
BrianL is offline   Reply With Quote
Old 02-13-2017, 01:20 PM   #3
Sledgehammer70
Lethal Camaro
Originally Posted by BrianL View Post
Hey Sledge,
The pins sit in a pressure tight fitting on the back side of the caliper. They are actually guide pins, so their main job is to make sure the pads stay in the right place/ angle.
But you use the punch to force them out of the tight fitting and when you put them back in you use the hammer to get them to sit tightly once again.
Old 02-15-2017, 01:20 PM   #4
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
Would you know what the difference is between z23 and z26? Really debating between these two
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 02-15-2017, 09:05 PM   #5
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
What did you do with the FS01 rims? I love the high gloss m017? you have now! Are they both same price? Where did you get your calipers coated at? Would that bottom lip thing fit on under a aftermarket splitter (RPI)? Did you add a supercharger?!(noticed you have a new hood), what did you do with old hood?
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 02-19-2017, 01:11 PM   #6
Sunsnare98
Drives: 2017 camaro ss
Wow...you asked like 10 questions. Just pm him.
Sunsnare98 is offline   Reply With Quote
Old 04-05-2017, 07:51 AM   #7
camaromike77
camaromike77's Avatar
Drives: S O L D
Are these available for the 2017 2SS ?? Can only find model year 2016 and earlier......... Thanks.....
Club F1FTY
Old 04-05-2017, 08:50 AM   #8
Adrian97c
Adrian97c's Avatar
2016 & 2017 = identical cars
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 04-05-2017, 09:05 AM   #9
camaromike77
Drives: S O L D
Thank-you Adrian97c. Much appreciated!
Club F1FTY
Old 04-17-2017, 05:28 AM   #10
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
Hey Sledgehammer, since you have had these brake pads for a couple of months, are you still happy with them? Any brake squeal? Thanks.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 04-18-2017, 07:23 PM   #11
Dub9
Drives: F1fty SS
Just saw these. Would it be worth swapping out my stock pads immediately, with only 60 miles on them?
Dub9 is offline   Reply With Quote
Old 04-18-2017, 08:52 PM   #12
AlphaCamaro7
Performance wise they're the same but if you're looking to have less dust and grime then these are amazing for that.
Old 04-18-2017, 09:18 PM   #13
Yellow6thGen
18 ZL1 A10 Convertible
Yellow6thGen's Avatar
Drives: White ZL1 Convertible
Are you still happy with the Z26 pads I'm pulling the trigger if you're still happy!
2018 ZL1 Convertible A10 @ Kooks R&D.
Yellow6thGen is offline   Reply With Quote
Old 04-18-2017, 09:57 PM   #14
AlphaCamaro7
Oh yea barely have to clean the wheels and tire and wheels look a lot cleaner every week instead of the dust changing its color.
