TireRack
Old 05-29-2015, 01:34 PM   #1
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
dead battery after sitting 9 or 10 days
I have a 2014 1LE and after sitting 10 days it has a dead battery . Anyone else have issues with this ? Charging system is working/charging , original battery is just over a year old .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 05-29-2015, 02:07 PM   #2
Rick's Camaro
Drives: 1967-2014 Camaro's
Heat can actually affect the battery more than the cold can, you live Arizona so the heat could be to blame. Bubbling and evaporation could have occurred but that is again an opinion.
Rick's Camaro is offline   Reply With Quote
Old 05-29-2015, 02:09 PM   #3
Whoomba
Drives: 2024Camaro 2SS CE Convertible
I've had mine since Jan of 14. No issues yet. Maybe the heat or a light left on?
Old 05-29-2015, 02:13 PM   #4
GONIF
GONIF's Avatar
no light left on.
Old 05-29-2015, 02:23 PM   #5
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
Get a trickle charger and problem solved.
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 05-29-2015, 02:38 PM   #6
GONIF
GONIF's Avatar
ORDERED THE CTEK MULTI 3300 56-158 . But I still think the battery is weak for it not to last a measley 10 days in a garage.
Old 05-29-2015, 02:50 PM   #7
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
with your car being that new, I'd take it to dealer. They will likely give you a new battery and check to ensure there are no drains. My car sits in garage during winter for weeks without issues... I start it up a few times and don't use a maintainer.
you might have a dead cell.
maddoggyusa is offline   Reply With Quote
Old 05-29-2015, 03:02 PM   #8
Blk-Ice
Blk-Ice's Avatar
I had the same problem because of my rapid fire tail lights which draw power somewhat if your vehicle is left unstarted for an extended period of time. I just keep mine on a trickle charger since its not my daily driver. In your case since your vehicle is so new and still under warranty i would go get it all checked out.
Old 05-29-2015, 03:19 PM   #9
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
That sounds like a good plan, I would think that battery should last longer than that without a charger.
Old 05-29-2015, 03:53 PM   #10
Chevy_cowboy
Chevy_cowboy's Avatar
Drives: 2011 IOM 2SS/RS M6 Convertible
Thats a great charger/tender I've got a couple of them.
Just curious, was the battery full charged when you parked it 10 days ago? I mean had it been driven long enough to fully top off the battery? Many times people don't realize that driving short trips can be a cumulative drain on the battery. My wife's had to be charged every couple of months when she was working because her commute was half a mile. 2 starts every day with a a very short drive would drain it in a matter of weeks.
Chevy_cowboy is offline   Reply With Quote
Old 05-29-2015, 03:57 PM   #11
SabotAndHeat
SabotAndHeat's Avatar
Drives: 2010 Camaro
Have you made a call using OnStar recently? After your'e out of your car, keys are out and door is shut, look at the screen and see if the screen is off. Then see if your bluetooth is still connected by phone and make a call. If your car rings, you may have to reset the car by battery.
I had this happen once. I had bluetooth turned off, so my phone didnt auto connect. Went to make a call and onstar popped up. I immediatly hung up and connected by Bluetooth. But, started to notice when I was just outside of my garage or in the house close by...the car would ring. This lead to my battery almost going dead one time because it wouldnt actually shut the electronics down in the car.
I fixed it by reset.
It's a long shot...but maybe.
SabotAndHeat is offline   Reply With Quote
Old 05-29-2015, 04:10 PM   #12
jd10013
Drives: 2012 camaro
yep, heat is what damages them, not the cold. you just don't notice it when it's warm and the car needs a lot less amps to turn over.
jd10013 is offline   Reply With Quote
Old 05-29-2015, 06:30 PM   #13
GONIF
GONIF's Avatar
MOST DEF FULLY CHARGED, when last parked .last trip was 22 miles.
Old 05-29-2015, 06:34 PM   #14
GONIF
GONIF's Avatar
No onstar ,free time ran out and im not paying for it so its not that . My XM ran out on the 28th and im wondering weather to renew or not .
