05-13-2019, 03:59 PM | #1 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Katech Dual-Threat Street/Track Build
Hello All,
My name is Zach and I am part of the engineering team over here at Katech. In this build thread, I will be showing you how to build a track focused 5th generation Camaro that has very street-friendly manners when you want it to. To start off my personal build, i'd like to show you guys how the car started. I purchased this car on May 28th, 2016 as a sub-15,000 mile Certified Pre-Owned vehicle. It was a 2014 Camaro 2SS with the RS, 1LE, Recaro, and NPP Packages. Fast Forward to now, this picture was taken a couple weekends ago after a beautiful track day out at Grattan Raceway in Belding, MI. And even further, the finished engine in the car carving up the Tail of the Dragon: As it sits, my car has a few essential modifications done to it to make it handle like it should have from the factory. With that said, now is the right time for me to do a complete rework to blow the factory handling out of the water. Currently, I am in the process of overhauling my vehicle to really make this car shine on the track while maintaining the street-friendliness that one would like out of a daily driven car. Below is a brief summary of what will be done to the car: • Katech 416 Stroker LS9.R Based Engine • Eaton Truetrac + 4.10 Ring and Pinion • Chassis and Suspension Work • New Wheels / Tires • Misc Graphics and Accessibility components A more specific outline of my build will be in the second post below. Best Regards, -Zach Last edited by Katech_Zach; 02-19-2020 at 01:35 PM. |
05-13-2019, 04:00 PM | #2 |
The following post contains a general build summary of what the final vehicle will have equipped. There may be more or less added, but this does a good job of summarizing what will be happening to the car over the course of the next month or two.
Engine: Block:
Chassis: Wheels:
05-20-2019, 10:42 AM | #3 |
Updated with a build summary above. Pictures to come. The chassis is nearing completion and engine components are being ordered.
05-20-2019, 09:50 PM | #4 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Very nice build!
Let us know what it lays down. Sent from my iPhone using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
05-21-2019, 02:47 PM | #5 |
A lot got done over the last week. I will update with as many pictures I can when I have the time.
First on the list was getting the newer extended GM studs into the front hubs. Very straight forward process and helps anyone looking to run a square setup with spacer options. You can now safely run an 8mm spacer with the factory amount of turns in the lugs. |
05-21-2019, 02:51 PM | #6 |
Car getting prepped to be ripped apart along with some of the quality components going into this build.
DBA 4000 XS Rotors, Ferodo DS2500 Pads, Bilstein B6 Shocks, and a US Gear 4.10 REM Isotropic Superfinished Ring+Pinion set. |
05-22-2019, 01:41 PM | #7 |
Drives: 2002 Z28 M6 Join Date: Oct 2008
Awesome build!
05-23-2019, 12:00 PM | #8 |
Out with the old, in with the new as far as shocks go.
Bilstein B6 Shocks seems like they will hold up to Michigan a lot better than the OEM ones did. |
05-23-2019, 12:02 PM | #9 |
Vorshlag Camber/Caster plates to go with the Bilstein B6 shocks. I still need to slot the top of the strut tower to get the maximum amount of camber adjustment out of this kit.
05-24-2019, 10:12 AM | #10 |
Updated Build Parts List:
-Improved Racing Crank Scraper and Oil Pan Baffle -Potential cooling upgrades with a DeWitts Radiator and Oil Cooling System -Fore Innovations Billet Rails -Misc Gold Heat Shielding and ARP hardware |
05-24-2019, 08:45 PM | #11 |
Where are you getting the gold shielding? What are you going to put it on?
I need to figure out an oil cooler. |
05-24-2019, 11:06 PM | #12 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I have the Vorshlags and I do not think with using an OE type front spring that you will be able to get max camber, the Vorshlag top spring seat OD is too big and it will touch the strut tower.
Nice build!
05-28-2019, 07:39 AM | #13 | ||
In the future, I will be getting coilovers that will use a standard coil spring. Thank you! Looking forward to getting this finished. The shortblock will be started this week. |
05-28-2019, 11:07 AM | #14 | |
I achieved -3.4* on mine with the Z/28 springs/struts, 305/30-19 ET20 wheels and a 12mm spacer. I've since backed it down to -2.7.
